airbag warning light
any ideas as to where & if there is a fuse for ren laguna airbags , mine is a 96 2.2rtd & the dash airbag warning light is illuminated & i would hope to avoid either a trip to the main dealers or a trip thru my windscreen !!!! many thanks for any assistance recieved
I would be surprised if removing a fuse would kill the warning light. Maybe just as quick to fix the fault. Presumably your car has front seat belt pre-tensioners. If so, the most likely fault would be the connectors usually found under the front seats. (Orange on Citroens) The explosive gadgets are all part of the air bag self check system. Disconnecting and re-connecting them (maybe with a blast of switch cleaner) usually solves the problem. It's a very common fault on 306's and small Fords. For safety reasons, disconnect the battery first.
I had the airbag light come on in my Renault Safrane 2.2TD 1997
the problem was connected to the seat belt sensor. someone I Know sent me to a mechanic with a diagnostic car computer who reset my
management system ,it was reading 9 faults . s\belts A\bags heater
sensors too. sometimes if you disconnect the battery leads for 24
hours the boardcomputer can reset itself,but no garantee
