CD Changer fonction on the WIPCOM3D / NG4 - Peugeot RCZ
This unit is the NG4 system, made by Harman Becker.
Main Features: DVD, Voice Commands, HighRes Display, 3D Mapping, Bluetooth Hands Free, Independent Phone with MDS Module, SD Card, USB, Jukebox.
slibby
Re: CD Changer fonction on the WIPCOM3D / NG4 - Peugeot RCZ
Unread post by slibby »
slibby
I have don't find information about HDD in the menus
slibby
Kees wrote: 22 Apr 2025, 12:44 The amplifier is behind the clove box on the right side.
And yes he's connected by canbus, there's also an other problem when you use a different system, because the speaker connections from the NG4 to the amplifier is different, so then you get no sound from some speakers, because the amplifier multiplex the signals over all speakers.
The signal between the amplifier and the speakers is multiplexed? really? So the speaker have electronics to un-multiplex the signal ?
slibby
Other I don't tell you that I have no sound in the car. Speakers deliver nothing.
Kees
x 74
Unread post by Kees »
That you don't see, the information about the hdd is, because the info you show is when you press the setup short.
The other one is the combination with the buttons 1,2,3, simultaneously with setup.
About the speaker connection, normal without the amplifier there are 8 wires comes out of the connector from the NG4, but with the amplifier there are only 4 wires, therefore is the multiplex system.
Kees
x 74
Here you see the connections between the NG4 and the amplifier.
slibby
Waw great ! Do you have also the nomenclature ?
The 8424 seems to be the Philips amplifier no ?
slibby
slibby
It's difficult to have this informations because the NG4 freeze then reboot randomly
slibby
slibby wrote: 23 Apr 2025, 20:35 Other I don't tell you that I have no sound in the car. Speakers deliver nothing.
It's not completly right. I have the sound of the parking radar in the speakers.
Kees
x 74
Oke,
It seems to me, your HDD is broken, you can do something to test the unit itself by removing the HDD, then the radio should work normally.
First put the gearlever as far as possible from the radio, then disconnect the battery. Pull the radio out as far as you see on the photo.
Then remove the tiny torx schrew (torx#9) and pull the HDD just a 1cm out.
Reconnect the battery and start the car, check if the radio is working.
If it is, you now now that the HDD is broken.
slibby
ok I'll try it. Thanks
Kees
x 74
Let me know the result please.
slibby
Yes I'll tell you. I have order the tools to extract on Amazon
Kees
x 74
If the HDD is broken, this one is the original one.
You can find this on Ebay.
I have the image to format it with the software.
