Likewise dry sunny winters day favourite kind of weather. Hate the rain can't do anything in it. Too warm and you can't move. Yeah so all good on all fronts so far a few issues but I think I am pretty much there with it for now at least. The rain seems to like weekends sunny and dry all week and then bloody rain for the weekend.MattBLancs wrote: 17 Nov 2024, 14:54 Ha ha, good news on all fronts!
Yes I hate the wet too, would take icy cold (but dry) over a good few degrees warmer but raining any day of the week (end!)![]()
Injectors misbehaving but trying to understand the numbers
- x 256
Re: Injectors misbehaving but trying to understand the numbers
Darren
- x 1799
Yep, Sod's Law kicks in with the weekend weather very often!
- x 256
Ordered the seals for bearing end cap and rear mains. €40 including shipping I have a brand new tube of dirco as well. It involves pulling the sump so I have a good bit of work ahead of me but I don't need the hassle of trying to do it on the car.
There's that much oil there I couldn't tell where it was leaking from so just going to change all of them it's an extra bit of work but easier done on the crane. I don't want any reason to pull the engine again once it's installed.
im going to pressure test the cooling system off the car as well so I don't get any nasty surprises.i should have done this first before I done all the other work but hindsight and all that.
Bucketing down rain here again today so i will be leaving it alone until it dries up a bit.
Darren
- x 1799
Did you find yourself a stand in the end? I know we talked about them a good while back, but they seem to have jumped up in price since I bought my (£30-odd) one a few years ago
- x 1799
Seems to be cheaper time again, £46.79 from a quick search:
https://www.ebay.co.uk/itm/125195288009
- x 1799
Google has dug up some even cheaper:
https://search.app?link=https%3A%2F%2Fw ... s%2Fm2%2F4
= £34.50 free delivery!
- x 1799
Was also going to suggest this one, just £21, till I saw the dimensions!!!
Sharplace Rotatable Simulated Stainless Steel V8 Motor Engine Flip Maintenance Repair Bracket Stand Lightweight Accessory, Black https://amzn.eu/d/3Ifxuk0
- x 256
I did Matt yes I got one earlier in the year but I think it was would get in the way for what I have left to do. One of these.
https://ige.ie/commercial-engine-stand- ... FVEALw_wcB
Darren
- x 256
Hi all, finally got back to the car today. I was sick the last couple of weeks with flu
or something so had to wait on it to go away accompanied by the fact I had pulled something in.my back
dragging the engine crane around so out of commission and a bit cautious.
Any way I pulled the sump cleaned it and done the bearing end cap seals and rear main seal. I never took photos as i forgot to bring the phone out with me. I also reinstalled the flywheel clutch and gearbox.
I need to reinstall the loom again as I had discovered a few damaged connectors and had to repair them. I've also to
Reinstall the starter motor and the injectors. The injectors are sitting in a box after being tested and cleaned so all going well I should have the engine and gearbox in the car tomorrow and hopefully running by next week.
Darren
- x 144
How did you get on with the timing belt ?
You probably posted earlier about it but I must have missed it.
When I did my timing belt on the X7 I removed the starter motor to give better access to the timing hole on the fly wheel. But with engine out it would be a lot easier.
Kenny
Kenny
C3 1.4 petrol (SWMBO)
- x 256
Hi Kenny, I put a new gates kit onto the replacement engine. If you look back a few posts I had a bit of fun with the timing belt actually the water pump more so as it was heavily corroded on the replacement engine.
I have the engine and gearbox back in the car now so mission accomplished for this weekend at least.My engine crane is starting to leak so not too soon either. Just have to install injectors and ECU and driveshafts etc. now. I'll do that in the evening after work if I get time.
Darren
- x 144
Okay got it, slow but sure and you will out on a test drive soon.
Kenny
Kenny
- x 1799
Starter off for flywheel timing position hole = yes, same here.
Engine crane leak = I was surprised how cheap replacement rams are, £30 or so on eBay for complete item. Current one might be fixable but time spent doing that is taking you away from the car
Engine stand looks excellent, more robust than my cheap one. Looks to fold up like my engine crane, legs upwards.
Good progress by the way
- x 256
Yes Kenny, I hope so. I'm not putting a date on it because every time I do something goes wrong.
Yes starter off for timing used the old dual mass flywheel off the donor engine to time it up then installed my smf kit it all lines up right so happy timing is spot on.
I saw a ram for €60 so I might pick it up instead of trying to repair the old one. Hoping I won't need the crane any time soon. Engine stand is robust and folds up like the crane but it is a it wide for getting inside the crane so you have to rest the legs on the crane which makes it awkward to use. I figured out how to buy it s a bit frustrating. As I say hopefully won't be required until the summer when I hopefully have time to work on my Maxima
Darren
- x 1799
Ah, yes understand what you mean about crane + stand legs in the way of one another. Mine has smaller wheels and a smaller frame. I guess it must just pass under my crane's frame as I don't remember having a battle like that!
Just a quick search, £33 for a 4 tonne rated ram:
https://www.ebay.co.uk/itm/315633313031
Or £36 for an 8 tonne:
https://www.ebay.co.uk/itm/133837165173
As you say, hope not to need it!
