Aisin Tf-80 / AM6 Oil Change Questions (Mini-Guide Page 4)
x 6911
Re: Aisin Tf-80 / AM6 Oil Change Questions (Mini-Guide Page 4)
Depending on your vehicle's Euro Standard You'll need either:
JWS 3309 for Euro 4 Vehicles
JWS 3324 (Type AM6-2 / AM6-2 / AT6/ AT6-3) - equivalent to AW1 for Euro 5 or Euro 6 Vehicles.
Harcix
Unread post by Harcix »
Yes, that i already do know, its a 2012 508 163hp. Its the JWS 3324 i need. Just wanted to check, if you have any opinions on that particular oil
https://www.mannol.de/create-pdf/270/en
x 6911
We only recommend the official oil, but as long as it meets the specific requirements for the gearbox and Euro standards you should be ok.
Mostafa Mahmoud
Unread post by Mostafa Mahmoud »
Hi,I want to know the gearbox type installed in my car
and the oil specs as well. my VIN is VF3**************[VIN obfuscated, can be read by forum staff]
i need a way to help me to know if a certain oil is suitable for my gearbox or not from its specs or datasheet.
thank you
Mostafa Mahmoud
Hi
is it ok to use this oil "ATF WS Lifetime" specs are shown in the images
my vin code is VF3**************[VIN obfuscated, can be read by forum staff]
shelleyamy
Unread post by shelleyamy »
Hello
Can you confirm the oil i should use for VIN VF3**************[VIN obfuscated, can be read by forum staff]
Mike
x 6911
MIke, you have a Euro 5 vehicle, so this requires JWS 3324 Gearbox Oil. Don't forget to reset the oil counter with a diagnostic tool and you will need 2-3 changes to get to as near a complete change as you can.
x 6911
Mostafa Mahmoud wrote: 09 Jun 2024, 08:24 Hi
I've only just seen this post, a bit late for a reply but the same for you JWS 3324 Oil for this gearbox.
mbprado
Unread post by mbprado »
Hey!
I was reading the whole topic, and the information here is very clear, however, the vendors they don't help and their specifications are really confusing.
At my car (VF7**************[VIN obfuscated, can be read by forum staff]) transmission oil plug is written AW1, i understood as per Marc's posts that I shouldn't use in any circumstance JWS 3309 spec. What if the oil spec says: AISIN WARNER AW-1 and ATF 3309, like FEBI BILSTEIN 101161 🤷??? ?
Tks!
tenxob
Unread post by tenxob »
Hi All
Just to update some info.
Just changed EAT6 oil on 208 1.2L THP Allure ( 67 ) and some new info below.
All plugs now have O rings and no flat washers - Level/Drain/Fill
Amount that came out of min was 2.5L - so I put in 3 and when level checking 0.5L came back out.
Car was level and at correct temp etc.
Sorry no pics!
Mike
Gmsbh
Unread post by Gmsbh »
Hello, I would like some help from everyone to change the oil in my DS5, my VIN code is VF7**************[VIN obfuscated, can be read by forum staff], what would be the correct oil for my car? I'm confused.
IgorI
Unread post by IgorI »
Hello everyone! I have a Citroen C5, 2012, 2.2 liter engine, station wagon, diesel, VIN code VF7**************[VIN obfuscated, can be read by forum staff]. I want to change the oil in the automatic transmission. And the question is - can I use Toyota AT Fluid WS for oil change?
x 6911
You require JWS 3324 oil, or equivalent to this.
IgorI
The official Citroen dealer in my city said that Citroen uses special transmission oil for the automatic transmission, its cost is 210 euros for 4 liters. It seemed too expensive to me. A regular Asin transmission.
x 6911
The oils are different, often based on Euro standard of the vehicle (Euro 4 or 5/6) and gearbox (remember there were multiple versions of the AM6 gearbox fitted over the years). You have a Euro 5 vehicle.
The dealer is correct and you did ask - but can't help if you don't like the answer. Yes the oil is expensive, but look for JWS 3324 or equivalent.
