x 8159
Re: I am an Activa owner...a V6 and I am an addict
Stickyfinger wrote: 10 Aug 2017, 22:39 Interesting SC CAR (Indication) modification
http://alain.jaeger.free.fr/Visudiode-.pdf
Sweet and very well executed indeed :)
Worth doing and an excellent guide... The pictures say it all. The text is not needed really!
x 1976
Unread post by Stickyfinger »
More headlamp work.
A TEST of adhesive (so not in anyway neat) strength on the 3mm clear lexian sheet I have obtained........seems to work
x 1976
Headlamp conversion work progress....testing is getting there.
x 8159
Gosh! That headlamp test has made the paint fade a bit Alasdair :lol:
And destroyed the front numberplate! They must be powerful ;)
x 1976
the sun fades red lot..but zero lacquer peel :)
x 8159
Stickyfinger wrote: 18 Aug 2017, 08:39 the sun fades red lot..but zero lacquer peel :)
Odd how some colours do and some don't.. I still don't understand how red can peel so badly, dark blue a little and other colours hardly at all...
Can you explain Alasdair?
x 1976
Metallic Silver for example has a higher mica content thus the colour coat is quite "rough". As such the top coat has to be both thicker as well as having more to "grip" to the colour coat substrate.
I suspect the reflection rate keeps the colour coats cooler/less expansion/less micro cracks/less moisture penetration under the top coat into a porous colour coat (1980/90's technology/water base colour).....as I understand it.
x 3280
It could be worse. I remember when there was a bit of a furor when the car manufacturers changed their paint formulas (for environmental reasons, IIRC), and it turned out that bird droppings caused damage to the newer paints. Quite a few customers were unhappy with that.
x 8159
That's an interesting thought Alasdair... Makes a lot of sense :)
How then does one explain when Ford introduced metallic silver in the early 60s (Silver Fox IIRC) it suffered terribly from lacquer peel?
James, bird droppings are lethal to a lot of paints and surface coatings in my experience... Got to clean it up ASAP...
x 1976
Peel/flake is caused by a thin and brittle gloss coat suffering micro cracks (and customers not polishing with WAX)....the Ford stuff will just be to thin (and no WAX on it to protect)
The lesson is you can blame the company but you also have to blame yourself as well. Ultra thin "modern waxless" super polishes are only good for going on top of a WAX coat.
x 8159
Ahh, so that's what I did wrong with the Activa then - I never polished it enough with the right stuff :(
Now you tell me :twisted:
Now, had I known that in 2008 I'd still have an immaculate Activa...
x 3280
CitroJim wrote: 18 Aug 2017, 12:08 Ahh, so that's what I did wrong with the Activa then - I never polished it enough with the right stuff :(
And I thought you were a Karate fan! What was it the young lad was told in "The Karate Kid"? 'Wax on, wax off'.
x 8159
Hell Razor5543 wrote: 18 Aug 2017, 12:15
:lol: Good one James!
Sadly, I never did perfect that technique :roll:
On that subject, I've recently had to give up karate due to my deteriorating cognitive health :cry: I can no longer marshal the necessary mental ability to perform the techniques effectively; any task requiring much simultaneous mental and physical activity is now beyond me...
For this same reason driving is now extremely difficult for me...
It's a good job very little is needed to run, swim and cycle :) I am now just concentrating on those three activities...
x 1382
Unread post by xantia_v6 »
Stickyfinger wrote: 09 Aug 2017, 10:17 Thomas Beligné says:
V6 Activa have specific regulators, they are firmer than the others. They "should" however switch.................but how much is "firmer" ?
Have you checked on service.citroen.com? My recollection is that all Xantias have the same rear hydractive valve body (including dampers), and all except the Mk1 V6 use the same unit (as the rear) at the front. The Mk1 V6 uses the XM valve at the front. I don't recall that the Activa uses different valves, but I can't check, as service.citroen won't let me in at present (it gets upset when I change countries).
x 1976
Cutting out the headlamp glass
