Death of another Activa now double trouble
x 8168
Re: Death of another Activa now double trouble
Flapjacks :D The answer to every question and universal fixer of everything. Life always looks better after eating a decent home-made flapjack ;)
It's why I always have a tin of them available. They're like a first aid kit...
Well done on the work Holm!
holmedog
x 5
Unread post by holmedog »
Bake me some flapjack please Jim. Now I have a leaking fuel tank by the looks of things. Going to have a proper inspection at the weekend to confirm my suspicion.
Sent from my Tab2A7-20F using Tapatalk
Gun Metal Grey Activa turbo,R.I.P. Gone to scrap yard in the sky and jims garage
Blue Activa from dr.madvibe
Silver Activa lost soul
x 1978
Unread post by Stickyfinger »
Now there is a new catchphrase !
Well well well, "Bake me a Flapjack "
x 8168
Sounds like I need to prepare a batch of emergency flapjacks!!!
Holm, a leaky fuel tank is very unusual unless it's taken a hit from something as it's made of plastic...
I expect you'll find it's perished piping to the fuel filter or even the fuel filter...
holmedog
x 5
I'm thinking maybe the filler pipe possibly as it only seems to leak when I fill it up more than £40. Then only when filling her up not when stood.
Sent from my GT-I8200N using Tapatalk
x 8168
Yes, that's very likely... Check the pipes in the wheelarch...
holmedog
x 5
Green fluid now leaking from guess where now. The pump itself. Have thought of pinching it off the silver one but would need to get one to put back on that one. So need to know will any pump fit off any xantia or would it be a specific one for the Activa.
Deanxm
x 87
Unread post by Deanxm »
Are you sure the pump wants replacing or just new O rings, two minute job.
If its shot then any 6X2 Xant pump will do.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
x 8168
Whereabouts is it leaking from?
You may need to give it a good clean first..
One favourite place now is the suction (inlet) pipe. It cracks under the clip and the split can be almost invisible but it will leak, especially when the engine is stopped... When the engine is running and there's a good suction in effect it does not leak which can be confusing!
Otherwise, as Dean says, it'll just be the usual seals...
holmedog
x 5
Thanks for the advice i will have a good look this weekend. Hopefully i will get it sorted ASAP.
holmedog
x 5
These are the pictures of the hydraulic pump.ImageImageImage
Any suggestions gratefully appreciated.
x 1978
Yep.....sort the leak before it stuffs your Alternator as well, which it will very soon.
Others better qualified on pumps will tell you how.
x 8168
And alternators on a TCT are not the easiest in the world to swap...
Firstly, give the pump a really good clean and then it'll be easier to see from where it is leaking..
Deanxm
x 87
yep, de-grease it and get it gleaming like a pin, you will never see where its coming from with all that crud everywhere, air flow in the engine bay can make the leak look like its coming from anywhere.
D
XM Prestige PRV6 92
holmedog
x 5
Hi all quick question . Are all the petrol fuel tanks for the 2.0 litre the same.
