Laguna - spongy brakes
Bill B
Unread post by Bill B »
Hi
A non-internet friend recently had the front pads on his Laguna diesel replaced. Now the brakes are solid when the motor is stopped but go to the floor when the motor is started. Maybe I should also mention the car was in the shop for work on the auto transmission when the pads were noted as badly worn.
The brakes have been bled several times with no inprovment.
Is there a special sequence necessary in bleeding them ??
Anyone have a similar problem ??
Bill B
