I bought a Mini Cooper (yes I know it is not French, but it has French engine) PSA 1.6 HDI 9HZ 109hp 2008.
It is okay if I drive it slowly, but if I want to accelerate quick the car goes to limp mode. If the pedal is pressed about 60% sometimes the boost is okay at the beginning but starts going low and back to OK a few times, after that it goes to limp mode again.
DTC - low boost pressure and DPF differential sensor
Things I have done(but did not help):
- EGR Delete
- New MAP sensor
- New DPF Differential pressure sensor
- New fuel filter
- Unplug MAF sensor
