Wiring loom for epic lucas pump
Mamps67
Unread post by Mamps67 »
Hi there
I'm definitely not car-minded, and I am baffled. My kangoo keeps cutting out when l slow down coming to junctions but restarts straight away. Pushing on the fuel pump wiring and using a cable tie to secure the connector helped for a while. The glow plug light comes on to warn me it is going to cut out. If l keep on the revs it is fine for a bit longer. Reading this forum l am wondering if anyone has any idea if l can buy just a wiring loom for the epic lucas pump. If so, where from? I have a Renault Kangoo 1.9d 65 2002. Seems a big job to cut and re-solder all the wires. Also, does any have any other bright ideas thanks? Manda
