Personally I would strongly suspect the master cylinder, the symptoms you describe are in keeping with it being past its 'sell by date'.
You could try bleeding the system and flushing it out, if possible use a pressure kit such as 'Gunsons' in order to make sure no air is trapped in the system, failing that then as above as far as I can see.
Espace brake failure?
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by taipan</i>
There is alsoa cyclical bearing type noise from teh nsf wheel. Which I hope is just a wwheel bearing. I was told to replace this first as this can sometimes cause spongy brakes.
Nonsense!
Sounds like one half of your split braking system has failed. However, it may be worth foing a full fluid flush and bleed if you haven't done so already. It could be something simple like a trapped air bubble, and the fluid will be past its best if its sat unused for a year.
Nonsense!
