I am getting a p0340 error, I have only just replaced both cam and crank sensors and the engine has run for less than 5 min's with the new sensors in, it was not showing any errors when running. It all seemed to be running ok and then it started to falter when i lifted my foot off the throttle then it just stopped and now won't start. I also don't get any live readings while cranking so no engine rpm, no cam/crank sync, no pressure readings etc, I have tried another ecu and it gives the same fault, i tested both ecu's last week and it was running with both so i don't think it is an ecu problem. I have previously tested the wires to both sensors but did not find any faults I have checked the cam belt and that has not snapped and it turning both the injection pump and the camshaft.
Before I start taking it all apart again and rechecking the wiring and sensors has anyone any other thoughts on what might be going on.
Cheers
Vince
