sloppy gear change
grattsim
sloppy gear change
Unread post by grattsim »
If I didn't have enough problems with my car, my gear selector has gone really sloppy, It seems to be at the mount under the gear stick. How easy is it to get at it once the heat sheald has been removed. Does the middle section of the exhaust need taking out? How much should I expect the part to cost?
