Megane RN Water Pump
TonyH
Unread post by TonyH »
I have a dry bearing type noise comimg from the engine, 1.4 16V, which i cannot locate or identify. It has been suggested that it could be the water pump bearing which is worn allowing the pump to catch on the housing.
Has any one had this problem or make other comments as to the possible cause.
