I want to improve the bottom end accelleration on my 1997 phase II
2.2TD Renault Safrane. I`m using redex diesel addative with good results and have installed a green free flow air filter.As no manual
is avalable for the car I don`t know if its a mechanical diesel pump
or electronically controlled there is a managment system I don`t know
if it controls the pump. I want to increase the pump delivery rate and increase boost atlow revs if possible. Any advice will be appreciated.
Mike
Safrane TD Tuning
following the Puegot Citroen and General links of this forum
I`ve got hold of several pictures/diagrams of Bosch Diesel pumps.
At first I was turning The Boost Compensator Anticlockwise but it
was raising the screw and the diaphram so I`ve reversed it and it
is now 2 full turns clockwise pressing the Diaphram and tapered delivery cam downwards combined with shortening the accelerator
cable, I got a small brass plumbing fitting and 5cm of central
heating pipe wich has taken a great deal of slack out of the cable
Iàm pleased with the better response at low revs and I haven`t turned
up the Pump Delivery Rate yet.
