OS drive shaft
Deane
OS drive shaft
Unread post by Deane »
Hello all thanks for having a great forum.
Been a Xantia owner for the last 4 years and just got my latest one, a 110Hdi.
This is the reason i'm here :? . I have clutch problems and need to take the box out and need advice how to remove the OS driveshaft. (plus any other tips :-D )
Thanks.
Deane
x 1222
Re: OS drive shaft
Unread post by Peter.N. »
Hi Dean
Welcome to the forum. Your best (cheap) source of information would be a Haynes manual. The o/s shaft involves everything that the n/s does with the extra removal of the centre bearing. These have to eccentric headed bolts which you have to loosen and then rotate them free of the bearing. If the bearing is obstinate I usually remove them by clamping a large pair of molegrips to the shaft and hammering them outwards.
If you don't have a manual the instructions are as follows: slacken the drive shaft nut with the wheel still on because its very tight, then remove the wheel. The lower ball joint will need to be separated so you can pull the hub off after you have removed the nut, you should be able to swing the hub out of the way although you may have to disconnect the anti roll bar, I can't remember. It should all become clear when you start dismantling it.
x 7242
Re: OS drive shaft
The Intermediate Bearing often seizes in its carrier and either it comes out easily or is a right ****
I'm doing a clutch now on an Activa and my method to deal with the bearing is as follows:
As Peter says basically. First thing to do is to undo the hub nut! Then..
Disconnect the lower swivel joint and pull the hub clear of the lower wishbone. No need to disconnect the track rod end...
Then undo, almost right to the end of their threads, the two 'hockey stick' bolts on the intermediate bearing carrier and rotate them clear..
The get a big blunt cold chisel and a 4lb club hammer and drive the bearing out of the carrier toward the hub whilst rotating the driveshaft.
If it doesn't come out easily just keep going and check the 'hockey' sticks are clear of the bearing. You can feel them and get an idea where they are. As I say, at times they can be very tight and difficult. Just keep going and bashing!
You may like to read my thread on replacing an Activa clutch as it's exactly the same job in a 110HDi...
http://www.frenchcarforum.co.uk/forum/v ... 14&t=54694
I'm experienced with this job so any issues, I can help! Be aware of the precautions you must take with the slave cylinder and release bearing... I will be speaking of those soon!
Deane
Re: OS drive shaft
Thanks for the replies and sorry for the late reply. Just wondering does the driveshaft pop off first and then remove the solid shaft. Thanks
x 7242
Re: OS drive shaft
Deane, once the intermediate bearing is released from its carrier slip the shaft out of the hub and then pull the driveshaft complete straight out...
gearbox must be drained of oil first...
Deane
Re: OS drive shaft
that's great. If you dont mind could you explain those banjo bolt. thanks
x 7242
Re: OS drive shaft
Banjo bolts, you mean what we call the 'hockey sticks' ?
They are two threaded bolts in the intermediate bearing carrier with 11mm nuts on the ends facing the gearbox... The opposite ends have what might be best described as a 'foot' and this 'foot' serves to lock the bearing in the carrier. Before the bearing can be driven out the hockey stick 11mm nuts must be undone almost to the ends of their threads so that each 'foot' can rotate through 90 degrees to enable the bearing to push out of the housing...
When you get down there and look it'll all become obvious what I've described...
Deane
Re: OS drive shaft
great, all clear now, well as clear as its going to be.Thanks
x 7242
Re: OS drive shaft
It'll become even clearer when you go and take a look Deane!
Any more questions, just shout, always happy to answer ;)
Deane
Re: OS drive shaft
Hello again Jim, don't know why I called them banjo bolts!. Any way got the box out and thanks again for your help. It seems that there is something wrong with the thrust bearing set up. Would you have photos/advice on what it should look like, there seems to be bits that have fell off/ broke. Thanks.
Deane
x 7242
Re: OS drive shaft
Hi Deane, it sounds like your clutch has fallen victim to the same problem as the Activa clutch I'm doing right now. Basically, the release bearing should he held into the centre of the diaphragm spring by a C clip. The release bearing can pull right out of the diaphragm spring and become damaged...
The clutch is known as a 'pull' clutch where the release bearing is pulled toward the gearbox to disengage the clutch. This is opposite to the conventional push type clutch where the release bearing is pushed into the diaphragm spring to disengage the clutch.
Keep following my blog on the Activa clutch job and all will become clear.
Do be aware the release bearing cannot be renewed separately and nor can it be reused...
When fitting a new clutch assembly the release bearing is placed in the forks of the actuating arm and slid to the back of the guide tube but is not clipped into the diaphragm spring. The release bearing is pulled into the diaphragm spring when the gearbox and engine anre once again mated using a special hooked tool...
Later I'll find some more notes and pictures for you...
Deane
Re: OS drive shaft
Hello Jim, got the car sorted, new clutch fitted and back on the road. Just wanted to thank you for all your help, it much appreciated, especially from my wallet!
Deane
x 7242
Re: OS drive shaft
Excellent :D Well done Deane.. Good work!!!
Deane
rear of car sinking
hello all again,
just wondering does a leaky sphere on the rear of my car cause it to sink when switched off.
Deane
Deane
sinking rear
meant to say its a xantia 110
