Savanna 21~heater/fan not blowing
oneladydriver
Unread post by oneladydriver »
car heater not blowing/heater dials not illuminated have checked the fuses in fusebox under steering wheel-these are all working. Are there any somewhere else to check out?
baz114
Unread post by baz114 »
check wireing that connects to the fan motor because if one or more burnt out at the connection this will happen. i had same problem and disconnected the original connector and replaced with spade connectors and placed them into there original position and heater now lights up and works properly
oneladydriver
Thanks Baz114~will have a look![:)]
