Renault Laguna dashboard backlight
tolis14
New User
Unread post by tolis14 »
Hello to everybody in the forum...
I have an issue and I was wondering whether it has occurred to anybody else. The backlight in the instrument cluster flickers in a specific area, namely the lower right side of the rev counter and the lower left side of the speedo. The flickering occurs only in this area (the fuel and temperature gauges in between are ok) and only when the dimmer is at its higher (brighter) setting. If I lower the brightness it doesn't flicker. I forgot to mention that I'm referring to a 2011 renault Laguna 1.5 dci tomtom edition. Any ideas?
Thank you...
