Scenic I, Access to Washer Pump reservoir - effort?
mpdevice
Unread post by mpdevice »
Hi!
Anybody able to tell what one needs to to to get access to washer reservoir? Completely invisible from the outside.
I would need to exchange pump/selector valve assy which is dodgy. :evil:
I suppose it is wheel off and arch cover off or so.
I have some useless picture from some manual which shows it clearly but that is of course with the rest of the car removed :)
Thanks!
Michael
lexi
x 138
Re: Scenic I, Access to Washer Pump reservoir - effort?
Unread post by lexi »
That is the usual way with most cars now. Heat the clips with a gun and use the proper plastic two pronged tool so that the heads don't break off the stud clips.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
mpdevice
Good tip, it's cold outside. I hope that is the way forward. Thanks!
