Lag 2 no windows
bpowell555
Lag 2 no windows
Unread post by bpowell555 »
Hi, front windows were flaky for a while after water ingress through the scuttle then stopped. Briefly came back to life then died completely, then the rears stopped.
Anyone heard of this before? I was thinking UCH but could the drivers switch also cause this or another electrical fault somewhere?
UCH replacememt maybe 250 so not too bad given car doesn't cost me anything but how would I confirm its that, or test something else?
Don't want to scrap it for such a stupid fault since the drivetrain is faultless at 165k!
Cheers
Sharman1304
New User
Re: Lag 2 no windows
Unread post by Sharman1304 »
I have ben having the same problem with my lag 2, the rear windows go down by themselves I will be changing the drivers switch to see if it helps, I will keep you posted on what happens
bpowell555
Great! Let me know how you get on. 1 switch a lot cheaper than a whole new car,
Cheers.
