Hi All...
Is there a way of finding out which type of steering joint my cx (g reg tgd safari) uses other than by removing it?
My mechanic thinks it's 'not the tapered one' but I still can't really tell from the pictures of the ones I've seen which is which.
Any thoughts gratefully relieved...
OLIx
Inner steering joint...
2smv627
Re: Inner steering joint...
I find if you put it on full lock you can squeeze the rack gaiter and feel whether the inner joint is tapered on the inner most part or not, I have found that most suppliers over here only sell complete arms anyway - not much difference in price to a single inner from CX-basis.
- x 94
i just did a goooogly search for CX tie rod inner joint, i know it dosent answer your question but might be of use
http://www.rockauto.com/catalog/raframe ... or%2BAISIN" onclick="window.open(this.href);return false;
Regards, malcolm.
