A few CX questions...
Stormrage
Unread post by Stormrage »
A few questions I've got, thought I'd stick them all in the one thread :mrgreen:
* Can anyone recommend an outdoor cover? Sadly the new garage will not be done until this time next year (the old one is so unstable I wouldn't trust it..... and it's not long enough!) so I really don't want to leave her completely exposed to the elements.
* Does anyone know how to programme a PLIP key to the car? I have managed to get hold of one but whenever I google it I just get results for pairing a Xantia key with a Xantia :S
* Tyre pressure - the pressure given in the manual seems very low to me, I wondered if there was a general concensus in the CX community about the tyre pressures?
* Headlight Bulbs - I might have got this wrong so bare with me! - The bulbs that are currently fitted produce a yellow light which I assume is in keeping with the originals, can anyone recommend somewhere I could get replacements from that also produce a yellow light?
* Oil Additive - Usually when I service my cars I add Slick 50, but I have noticed in the owners manual it says you shouldn't use any additive - does anyone know if additive causes any harm?
I think that's all for now :lol: thanks for humouring me and thank you very much for any advice offered!
Cheers,
Ash
Citroening
x 19
Re: A few CX questions...
Unread post by Citroening »
Stormrage wrote:* Does anyone know how to programme a PLIP key to the car? I have managed to get hold of one but whenever I google it I just get results for pairing a Xantia key with a Xantia :S
I'm not 100% on this, however I believe that if you have just got the plip remote you'll also need the receiver that matches this (although I seem to remember mention of someone decoding some or something...). Either way, the original Plips are pretty useless mainly due to being through infra-red technology. Not many CXs have a working plip and if they do you sometimes see owners pointing at various angles through the windscreen to get it to work! :lol: I know a few CXers have retro fitted a modern plip system, here's a quote I found on the CCC:
cxprestigeauto from the CCC Forums wrote:It is all in the quality of the fitment! I bought the sensor and two remotes off Ebay not long after I got the car. Unfortunately the sensor is not just a plug in swap for the original central locking module since the connector strip is at 90 degrees to the circuit board albeit is with identical wiring I had to make up 8 connector cables with a female spade on each end and then link them all up. The results were however very pleasing. I am not sure how a later Series two unit would fit differently?
Probably not the same, but the BXers have done something similar - http://www.bxclub.co.uk/forum/viewtopic ... hilit=plip" onclick="window.open(this.href);return false;
Stormrage wrote:* Tyre pressure - the pressure given in the manual seems very low to me, I wondered if there was a general concensus in the CX community about the tyre pressures?
What wheels and tyres are you running? I seem to remember your car being on Alfa Alloys at one point, although I think it's on the original T-Slots? Pressures in the manual are the ones to go by...
Stormrage wrote:* Headlight Bulbs - I might have got this wrong so bare with me! - The bulbs that are currently fitted produce a yellow light which I assume is in keeping with the originals, can anyone recommend somewhere I could get replacements from that also produce a yellow light?
Have a look on eBay - you've two choices really. You can buy the yellow bulbs, or buy yellow caps that fit over normal H4 Bulbs.
http://www.ebay.co.uk/sch/i.html?_from= ... w+H4+Bulbs" onclick="window.open(this.href);return false;
http://www.ebay.co.uk/itm/Yellow-cap-fo ... 415c0ead8b" onclick="window.open(this.href);return false;
Franklin
Stormrage
Thanks for the detailed reply! :D
They are the T slots, 210 wide TRXs so I'll go with what the manual says :)
The infra red is working with what seems to be a ZX era remote (very small single button) but the rubber covering the button is wearing and it's only a matter of time until it falls off :lol: having managed to get hold of one of the original remotes I was hoping to get it working but I guess it isn't as simple as I'd hoped!
Excellent! I want to get some bulbs in stock as I don't want to be driving around with odd coloured bulbs! :lol:
thanks again,
Ash
Diabolical
Unread post by Diabolical »
Car cover I recommend pay a visit to Classic Motor Show Birmingham 16,17 and 18 Nov.
I bought a cover there 3 years ago waterproof, lined breathable wash car put cover on it will dry out.
Any how used every day 3 years 2 very hard winters only just started to lose waterproofing for £75.
There's always plenty discounted stuff mostly best bargains on the Sunday.
06 C5 2.0L HDi Exclusive Estate 20020k and rising. :-)
1987 Citroen CX Prestige. De Corps Brun Maya - cuir blond tabac, très chic
08 Jaguar X-Type 3.0V6 Sovereign Estate - Green (HGZ) - Leather Ivory seats.
citroencx.co.uk
Stormrage
Diabolical wrote:Car cover I recommend pay a visit to Classic Motor Show Birmingham 16,17 and 18 Nov.
Thanks David, that type of cover sounds ideal! I don't suppose you remember the make of yours? If not no worres :o)
I've posted the MOT Cert to you, sorry for the delay, very busy week!!!
