Just a quick one really as I'm pretty sure I know the answer...
2003 Espace 2.0 16v. Do the aux belts suffer the same fate as Citroens in that they can come off, wrap around the crank pulley and take the timing belt out?
My parents one has suffered such a fate, aux belt wrapped round the crank pulley (which looks rusty - are they dual mass?) finally extracted the belt after having to cut it but now, when starting, sounds like no compression and the crank pulley isn't turning.
Espace aux belt
- x 3
Espace aux belt
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
- x 3
Further investigation reveals a crank pulley in a rusty state but holding up despite being a dual mass affair.
Mainly though, have found the woodruff key for the crankshaft/crank pinion has made a bid for freedom and suceeded. It is gone. This will be why it is spinning but not firing, the timing belt isn't being driven so not operating the valve gear. Certainly sounds like no compression
Looks like there will be some bent valves on this one.
Toby
Previous:
Previous:
