C3 Aircon not working
Post your Cit/Peu/Ren air conditioning queries or advice.
Sl4yer
Unread post by Sl4yer »
Well, it didn't take long did it? :roll:
Only had it for 2 weeks, and the aircon isn't working. It appears (from Lexia) to be cutting out after a few seconds operation due to a High Pressure safety alarm. Does anyone know what would cause this?
Thanks,
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
Dommo
x 19
Unread post by Dommo »
Sounds like too much gas inside or the radiator cooling fans aren't working?
Sl4yer
That's a good place to start. I didn't think the rad fan was turning actually - thought there might be another one buried somewhere. I had a similar problem with my Leon some years ago, which was due to a blown fuse. Thanks Dom!
2008 Mazda RX-8 231
Dommo
x 19
No worries, it seems to be quite a common issue with some PSA cars, 306's off another forum I use all tend to have problems with rad fans!
pazauk
Unread post by pazauk »
Got the same problem with my c3! The temp gauge shoots to max and an alarm sounds, my rad fan does not kick in ( there is just the one? ) and there is a hissing noise when the air con is turned on. Did you get yours working again?
pazauk
