Hello,
I don't know if anyone can help here - any advice gratefully received.
Car falters sometimes. Doesn't conclusively seem to be speed related. Has lost power completely on a few occasions. RAC callout didn't help much - he wiggled some wires "in case", got a code 261 from OBD which "pointed to throttle body". Car restarted ok.
More faltering occasionally,then totally lost power today & had to get onto the verge pronto. Engine still running but accelerator had no effect. Switched it off, wiggled a few wires on top of the engine (ineffectually I suspect). Tried it before calling the RAC & it started & worked. Drove 60 miles with only a bit of faltering later.
This seems a to be an undocumented feature of Clios. I have found many reports on the web, but no solution and much opening of wallets while ECUs or whatever get changed as mechanics guess at the cause - the incidents are often a few years old so I wondered if the cause has now been identified?
I am under pressure to get it booked in, but I need to have an idea that the mechanics know what they are doing & not getting me to pay for miscellaneous guessing.
Cheers
Jonathan
Clio 1.2 51 plate losing power
If Stupidity got us into this mess, then why can’t it get us out?
51 Clio 1.2, 01 Avensis
