Hi Everyone.
I have a problem with my scenics headlights. its is a 1995 year car and when i took it for an mot it failed on headlight height, they were both too low. I have tried to adjust the with both the electical switch and manually with the adjuster screw on top of the headlight motor. Then I took the headlight motors out and cant get the back in so they are working, moving the headlights up and down. the motors are working fine when removed from headlights. How do you remove the headlights on this car, is it a big job? also is there a set way to refit the headlight motors?
