Scenic... clutch pedal part!!
StevieM
Unread post by StevieM »
Belated Merry Xmas.
Wonder if you can help.
Scenic '56 reg 1.9DCi.
Clutch pedal has felt "notchy" for past month.
Wondering if link to master cylinder had pbm, put my hand up above clutch pedal, and a short plastic linkage, approx 4" long, containing a broken spring, fell out into the footwell.
It consists of 2 parts, one telescopically slides in the other, with spring arranged to keep the separation.
one end is "forked", the other looks like it is moulded to push against a 5mm bar.
can anyone advise exactly what its purpose is??
Is it bad to drive the car pending getting this replaced??.
Car less than 3 yrs old when began to feel notchy.....springs obviously not up to its job.
Pls advise.
Many Thanks, Steve
