VELSATIS problems - 02 Plate
BECKS7
Unread post by BECKS7 »
Hi
Sorry to ask but can anyone shed any light on what i need to fix the following 4 problems with my 02 Velsatis. I thought i'd post them all as one to save cluttering up the board
1) When my car was last serviced they managed to change the mileometer to kilometers instead, which is driving me nuts. They're not sure how they did it, and hence how to change it back. I've tried a number of forums, but without success so far, and don't want to go to a dealer and get stung for what could possibly be an easy fix. I can get into some menus via the hold the stalk in then start the engine, but can't find the one to change this back.
2) Tyre pressure sensor faulty. How do i find out which one's faulty, and then how do i fix it
3) Reversing sensors not working. I've tried resetting them but they still don't work. I just get the beep that says there's a problem. Again any suggestions gratefully received.
4) Rear fog lights not working. Front ones work ok, as do all the other lights at the rear. I've tried swopping the bulbs over with the reversing lights and it's not them, and i've also tried swopping the fuse with another and again no luck. As it's both of them i think it must be some sort of connection, but i may be wrong
Many Thanks in advance for your help
Graham
faffer
Unread post by faffer »
Hi assuming you still have your issues.I have read abut this problem with Laguna2's on another forum and the general consensus is that the whole clocks unit has to be replaced. Did all these faults "appear" after this service?.
Dave
(If you want to pm me I can give you a link to the other forum)
Ross_K
x 110
Re: VELSATIS problems - 02 Plate
Unread post by Ross_K »
BECKS7 wrote:Hi
1) When my car was last serviced they managed to change the mileometer to kilometers instead, which is driving me nuts....
...and don't want to go to a dealer and get stung for what could possibly be an easy fix.
If they broke it they should fix it at no cost to you.
It sounds absurd but I remember reading somewhere that the clocks might need to be replaced when this happens, although I don't know how true that is.
Whatever the case the responsibility should be on the garage to sort it out. Take the car back and kick up a fuss.
