Clio coil problem
flygirl767
Clio coil problem
Unread post by flygirl767 »
Hi Guys and Gals,
I seem to have a problem with a petrol Clio (05 Reg - I assume that is 2005 - lol). It sometimes has difficulty starting in the REALLY (brrrrr) weather and the main dealer replaced a coil a few months ago. The problem has started again and the dealer says it needs yet another coil. What I would like to know is; how many coils does a clio have and, in addition, to save money can you buy them from your local motor shop and are they easy to fit as I get the feeling I'm being ripped off? The main dealer said it was a common problem and Renault had recently modified them so why should I have to pay for them fitting a faulty bit as original equipment?
All help gratefully received
Love, Michelle XXX
mazzicoupe
Unread post by mazzicoupe »
hi flygirl
i am in no way gonna be much help to you as i am deviod of all things mechanical but just to tell you that i had my coil packs replaced a few months back and it cost me £240 (for three) ... i thought i was getting ripped off and talkin to a friend of a friend last night ...he said i was too as they only cost about £20 each....so all i am saying is be wary!! :oops:
Mazzi :0)
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
hello Michelle,
I would concur with that.. I think 'pencil coils' should only be 20-30 £ each.. there should be four though.. I would say fitting is little more difficult than changing spark plugs, i.e. pretty easy
Whether you can get them changed as a 'recall' is a doubtful matter, but the fact that the new ones may be better may mean that car shops may not stock them yet ? worth getting a few quotes from indpendants, for a single coil swap only, see what they come up with ?
I dont have direct knowledge of the car/engine though :oops:
John
sparky33
Unread post by sparky33 »
As stated there are 4, you can usually get a brand new set for about £40 off ebay, just make sure they are not the "grey top" sagem ones, as they are the ones that fail.
Fitting is even easier than spark plugs, just remove the engine cover (if present), then one 10mm bolt (per coil) and they lift off, then just unplug from the loom.
They are a common failure so it's worth phoning Renault UK Customer Services.
http://www.renault.co.uk/ownerservices/ ... rvice.aspx
duv84
Unread post by duv84 »
I have just refited my coil pack on a 51plate 1.2 16v expression+ and from a renault garage I bought the whole coil pack for £47 inc vat!
sparky33
As far as I'm aware yours only has one coil and a set of HT leads?
