Clio Power Steering
Mike C
Clio Power Steering
Unread post by Mike C »
The power steering on my 2001 1.2 16v Clio (98 to 01 model) has stopped working and the engine management light has come on.
I have checked the fluid and it is full (Very full, is this normal?).
Are there any obvious checks I should do before taking it in to the garage?
Thank you for any help or advice you can give.
AndersDK
Unread post by AndersDK »
Check if the pump drive belt has snapped and is missing :wink:
Anders (DK) - '90 BX16Image
Mike C
The belt is fine.
It connects to loads of stuff on this model.
Rotates fine when the engine is running
AndersDK
- and the belt tension is fine too ?
(Please stop engine beforehand !)
I'm worried that you have an engine fault light, at the same time a missing power steering.
That indicates a gross fault on the drive belt, as it most likely also drives your alternator which could then set off the management light.
Mike C
The power steering has returned!???
There was a wire that led to underneath the starter motor and the connection was covered in crap. I cleaned it up and I have power steering again. I thought that power steering was mechanical not electrical?
Or do you think the two events are just coincidence?
Belt is fine and tight but the engine light is still on.
Does anyone know anybody in Milton Keynes who can find out why the fault light is on?
AndersDK
Seems you have 2 separate problems then.
You might have an elecric driven servo assist pump. That woud explain the perfectly topped up reservoir, but no steering assist despite a good belt.
You engine management light will then be a completely separate faut, most likely a dead simple service issue like afailing temp sensor or clogged air intake filter.
