Fault Codes: Bosch MP3.1
This is an ARCHIVE of common fixes. Material for this section should be submitted to an Admin or Moderator for approval then inclusion.
Guest
Unread post by Guest »
As fitted to XM 2.0, AX GTi etc
12 Start of fault code output
11 End of fault code output
54 ECM failure
22 Idle speed control
33 MAP sensor
52 Lambda sensor
51 Lambda sensor signal
53 Battery supply voltage to ECM
41 Crank sensor
13 Intake air temp sensor
14 Coolant sensor
21 Throttle position sensor
