Low pressure port.
Post your Cit/Peu/Ren air conditioning queries or advice.
Sir Clive
Low pressure port.
Unread post by Sir Clive »
I've bought a can of jollop and pressure gauge etc, to top up the gas on my aircon. I'm having a senoir moment here though, which is the low pressure side?
Of the pipes connected to the compressor, is it the one which gets cold when the system is running, or the other one.....
How embarassing :oops:
Regards to all
tomsheppard
Unread post by tomsheppard »
Easy enough, the can of refrigerant will only connect to the smaller of the two connectors. Ensure that the tin is upright and that there is a bowl of hot water to dunk it in to empty the tin properly. Good luck.
Be happy: it is a way of being wise. (Confucius.)
'92 TZD Estate(Grolliffe), Gone but never to be forgotten.
'95 405 GLX TD Estate. too new to name.
