Aircon indication C5
The green light that tells you the conditioning is on fails to light therefore conditioning not on, also the light for the recirclating switch also not lighting, have checked fuses as shown in Handbook both ok, suspect its an electrical problem, does it have a relay and if so where is it? or any other idaes, does anyone have a wiring diagram for the C5?
C5 Technical information
Try the Yahoo discussion group C5[L]. There is some technical information in French there.
Suggest you lobby Haynes to produce a manual as well. I have!
