First programming:
<b>Ignition on.</b>
1 Enter the code 0001
2 Press key C
3 Enter your personal 4 figure code.
4 Press C key to validate.
Four flashes of the green warning lamp and four audible "beeps" indicate the information is recorded.
<b><u>To Change the code:</u></b>
<b>Ignition switched on</b>
1 Enter your old code already in memory.
2 Press key C
3 Enter your new confidential 4 figure code.
4 Press key C to validate
<b> Security Procedure:</b>
The 2 codes (old and new) are then valid until one is used to start the engine.
Should there be no confirmation bleeps or flashes, turn the key off, then turn on and repeat the entire process.
If more than 4 figures are put in by mistake before pressing key C, only the first 4 will be memorised.
If both red & green warning lights are flashing simultaneously, this indicates an incorrect entry or malfunction.
Turn the ignition off, then on and start the whole process again. If this problem persiste, see you nearest Citroen dealer (Yeah right; always enjoy a good joke)
Alan S[:D][;)]
