Megane front caliper
This is the Forum for all your Renault Technical Questions, Problems or Advice.
davemar
Unread post by davemar »
Car: Megane 1.6 8v 1998,S-reg
Just found my front n/s caliper has seized up, not sure why its done this but its worn the pads out, and will probably need replacing. Is the caliper the same as a 205 GTi 1.9's? I ask because I also have one, so could swap it over if I'm desperate (the 205 is off the road at the mo). Trouble is the 205 is at home, and the Megane is at work so I can't compare the two. Also it seem GSF don't stock a caliper for the Megane, but do for the 205 GTi, so I could get one of those instead.
