Real fog lights on a 99 Laguna not working - swapped both bulbs....volt meter placed on connections on read..current flowing, hence no break in wire. Switch on steering colume taken off..nothing obvious....HELP, what else could be the problem..do Ineed a new switch box/column..could there be a loose wire pssible in the column?
In whci case, how much are these ?
Laguna - rear Fog Lights - not working
if you have a 12v supply at the bulbs, and the bulbs are known to work, then you have a faulty earth or the bulb holder is corroded, check the bulb holders first, then supply a temp 12v supply (connect a piece of wire from the battery and connect it to the positive side of the bulb)and see if this works the bulbs, if not, it sounds like a bad earth connection, so clean the earth wire or supply a new earth.
