Hi
I’ve recently changed my timing belt, a Peugeot 2008 and this fault code keeps popping with a permanent status. This has caused starting problems after the code is cleared
U1218 fault code and potential cause- change of timing belt
- x 25
Re: U1218 fault code and potential cause- change of timing belt
U1218 81 is electrical issue with ECU and some other CAN circuit. It is very unlikely that it is made by you changing the timing. However if you did not unplug the battery you might have shorted something by mistake. On timing side of the engine there is not much of a wiring. There is some wiring loom on the left back of the engine and crank position sensor. Check those for continuiti and shorting. Also at first I would try to check fuses and do BSI reset, just for a good measure.
Citroen C4 Picasso 2013, 1.6 e-HDI 85kW
Peugeot 206, 2005, 1.4i 8v, 55kW
Thank you for your feedback let me review
