Hello everyone!
I have had a problem with my Boxer for a long time, while driving it cuts out and records error P1632, I replaced all the relays and checked the engine wiring, but again I have no success when driving it cuts out and sometimes the engine dies, can you help me? Thanks !
Peugeot Boxer 2.0blue hdi 130hp 2018 (DW10FUD)
Peugeot Boxer 2.0BlueHDI P1632
- x 551
Re: Peugeot Boxer 2.0BlueHDI P1632
Not sure if this will help but might be worth a read
https://www.peugeotforums.com/threads/p ... as.369632/
Husky.
Hello, the car is currently in an authorized service center, they said that the fault is in the clutch sensor, they will replace it today and I will test it, I will write as soon as possible whether this was indeed the problem. Thank you !
- x 6916
You are missing the last 2 parts of the fault code. Without these it can be related to other things like the ABS system (P1632 00), or the engine management system (P1632 96 & P1632 48).LIPOTRANS-LTD wrote: 06 Mar 2025, 12:32 Hello everyone!
There is even a Technical Service bulleting for the DV6FC engines with this fault tht requires and engine ECU software update - so you can see without knowing the full code it could relate to multiple issues. But as you have taken it to a dealership, they should know the full code and the recommendation as they will have Diagbox for a proper diagnostic.
Full code is: P1632 47
- x 6916
Same then, an internal fault with the engine ECU.
The fault can also be caused by a defective EGR valve. If there are starting issues, it can be tested by removing the EGR connection and checking if the vehicle starts ok. If it does, then likely the EGR is defective.
We tested the EGR, even software and mechanically it was removed from the car, without improvement, today at the Peugeot Service they replaced the sensor on the clutch and now we will test whether there will be a problem.
Re: Peugeot Boxer 2.0BlueHDI P1632 SOLVED !
Hello, in my case the problem turned out to be the clutch sensor, I've already driven over 3000 km and there's no problem!
