The cabling is there so we are good on that front. Cheers.Hell Razor5543 wrote: 08 Oct 2021, 20:19 Before you look to buy the bits it might be a good idea to check the wiring is there. It SHOULD be, but you never know!
New Citroen Relay missing bits
- x 7
Re: New Citroen Relay missing bits
- x 7
All sorted Fiat saved the day. I collect them on Tuesday. Thanks all...
- x 7
Almost there. If anyone needs the parts the FIAT part numbers are 52200804 for the metal socket and 51932872 for the plastic holder with lid.
Both dashboard sockets are working now but the rear 12v socket is dead. The manual in MyCitroen app doesn't show fuses but online it says F9 in the engine bay should be a 15A, the problem is that F9 has no connections and the fuse can't be installed. I am hoping there is a new wiring diagram because the online manuals all say 2015 to 2018 and mine is a new 21. Any ideas??? Thanks.
I have a 2020 plate and can't find 12v plug for cigar lighter behind the rear panel at our.
Can see on panel where cigar lighter would go.
Anyone know if all relays com with the plug?
- x 6914
Equipment is dependent upon body type (commercial vans are supplied in multiple coach styles and differ considerably). trim level and then optional equipment.
Wiring harnesses are again different depending on what I've said above, so don't count on it being there. Only investigation will tell and don't forget to check the fuse is there too.
