What DS5 Head Unit is this?
This is the Connected NAV system.
Main Features: It is a fully integrated Telematics System featuring CarPlay, Android Auto, Real Time Services, Voice Commands, High-Res Display, 3D Navigation, Bluetooth Hands Free & USB. 2 versions of the system are available NAC (Navigation Audio Connectée) and RCC (Radio Couleur Connectée) or Connected Colour Radio, which does not have the Integrated Navigation or Live Services.
Peppazot
Re: What DS5 Head Unit is this?
Unread post by Peppazot »
GiveMeABreak wrote: 05 Mar 2024, 10:57 Ok, but be mindful they may charge you diagnostic time to do this.
Ok thanks for the heads up, i'll double check in advance :-D
Tekguy78
Unread post by Tekguy78 »
HI I have recently Rejoined the world of Citroen and Love my DS5
Im looking to find out some info about my car Like what model is the radio
any and all help much appriecated
x 6955
We'll need the VIN for that as there are different systems installed. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Tekguy78
HI Thank you
My VIN is VF7**************[VIN obfuscated, can be read by forum staff]
My Headunit code is
Unit ref - 9806710580
CD number - 8980
SW version RNEG2.86.B1
Car also shows when the radio is on right driver display says radio off
and I cannot change the Fuel readout to mpg
Can you advise the full spec of the car I.E if it has wireless entry.
Tekguy78
Hey
Is there any info on my stereo model. I would love to upgrade the unit to the touchscreen model
x 6955
You have an RT6 unit fitted. If you want a factory build sheet, you'll have to upgrade your membership (see below) as we have to pay for access to this data:
We can help if you need an original genuine part number, part diagram or vehicle factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 3 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
Tekguy78
GiveMeABreak wrote: 15 Dec 2024, 20:35 You have an RT6 unit fitted. If you want a factory build sheet, you'll have to upgrade your membership (see below) as we have to pay for access to this data:
HI Marc
I have donated and would love if its possible to get the build sheet. as i think a previous owner upgraded the Radio as mine has a few issues it reboots regularly and asks for a peugeot software update
x 6955
Sure, here's your factory build sheet and as you can see you have the RT6 unit.
I personally won't advise on retrofits as there are factors that can affect the outcomes like vehicle electrical architecture compatibility and configuration changes that will need to be made. However Mac Slavko has upgraded his DS 5 and he has written a post about it here that you may find helpful:
RT6 to NAC (Connected NAV) Upgrade
Vehicle Characteristics
Vehicle familyDS 5
AS/RP N°13318 89 2 0049
Warranty Start Date30/05/2013
Engine serial number10 DYZE 4081944
OPB0017
BERe2*2007/46*0092*05
P4A9803189999
General Information
PRODUCT TYPEPASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPEDS
VEHICLE FAMILYDS 5
SILHOUETTE5 DOOR SALOON
TRIM LEVELHIGH MEDIUM
ENGINEDW10CTED4 FAP TURBO DIESEL
TRANSMISSIONBVM6
PAINT TYPETHREE-LAYER PEARLESCENT METALLIC PAINT
BODY COLOURKWE - PEARLESCENT WHITE PAINT
INTERIOR TRIM TYPEHALF-LEATHER DINAMICA "3I"
UPHOLSTERY COLOUR"FZ"
GEARBOX (CHARACTERISTICS)GBOX ML6 CL
ENGINE (TYPE)EW/DW
Fuel Supply-Engine
FUEL SUPPLYDIRECT EXCHANGE TURBO INJECTION
DIESEL FILTER WATER DETECTORWITHOUT DIESEL FILTER WATER DETECTOR
CYLINDER BLOCK (MATERIAL)CRANKCASE CAST IRON
FUELDIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE)EURO 5 L6 UPPER ENGINE EMISSION CONTROL
ENGINE (TYPE)EW/DW
CAPACITY2000 CM3
OIL COOLERMNTG WATER/OIL EXCHANGER ON ENGINE
FUEL TANKFUEL TANK WITH LOCATING TAB
OPTIMISATION OF VEHICLE’S CONSUMPTIONNORMAL
CRANKCASE GAS CIRCUIT HEATINGWITH HEATER CASING GAS CIRCUIT
SPECIAL POWER TRAIN SOUNDWITHOUT POWER TRAIN TYPE
EOBD SELF-DIAGNOSIS SYSTEM"EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER
VEHICLE TECHNICAL DEPOLLUTIONTECHNICAL VEHICLE EMISSION CONTROL EURO 5
PARTICLE FILTERWITH PARTICLE EMISSION FILTER
FAN1 AERO 2-SPEED 140W FAN WITHOUT SCOOP
FUEL VAPOUR RETRIEVALWITHOUT PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANTMOUNTING DELPHI
DRIVE TRAININTERNAL COMBUSTION DRIVE TRAIN
TANK FILTERRESERVOIR FILTER INTERIOR
STOP AND STARTWITHOUT STOP AND START
Gearbox Transmission
TRANSMISSIONBVM6
FINAL DRIVE RATIOREAR AXLE HYPOID GEARSET 17 X 71
WHEEL STYLECANAVERAL 18-INCH WHEEL
CLUTCHHYDRAULIC CLUTCH
DIFFERENTIAL (GEARBOX)DIFFERENTIAL DIAMETER 86
RIM/TYRE SIZE18 INCH TYRE FITMENT
TYRE (SIZE, TYPE)235/45 R18 98W REINFORCED TYRE
WHEELS FITTED8 INCH WHEEL
WHEEL (TYPE)ALLOY WHEEL ASSEMBLY 2
INFLATION PRESSURE LOSS INDICATORWITHOUT TYRE DEFLATION INDICATOR
GEARBOX TYPEML6C
Suspension-Steering-Brakes
ABSWITH ABS BRAKES
REAR ANTI-ROLL BARREAR ANTI ROLL BAR DIAM 27
FRONT ANTI-ROLL BARFRONT ANTI ROLL BAR DIAM 23,5
SUSPENSIONNORMAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEMELECTRONIC STABILITY PROGRAM
BRAKE ASSOCIATED VARIANTBOSCH 8.1 ESP
PEDAL BRACKET (TYPE)PEDAL STANDARD
Body Fittings
TOWBARWITHOUT TOWBAR
HORNSHORNS-HARMONY
AERIALAERIAL + GSM + GPS
REAR SPOILERWITH TAILGATE UPPER SPOILER
SIDE MOULDINGS (TYPE)CHROME SIDE PROTECTORS
SIDE MOULDINGS (DIMENSION)THIN LAT PROTECTORS+CHROME SILLS
WHEEL EMBELLISHER (STYLE)CABOCHON HUB COVER
UNDERBODY SHIELDWITHOUT PROTECTION UNDER BODY
INDICATORSSIDE MARKER LIGHTS
SILL ILLUMINATION LAMPWITHOUT SILL ILLUMINATION
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
EXT. LOAD RETENTION RING (ATTACHMENT)BOAT + LORRY EXT LASHING RING
EXT. REARVIEW MIRROR COMP. FUNCTIONEXT MIRROR ELECTRIC-FOLD BACK
ENGINE BAY SOUNDPROOFINGBULKHEAD SOUNDPROOFING + BONNET + SHORT ACOUSTIC POWER TRAIN
WINDSCREEN WIPERFRONT WIPER BLADE WITH RAIN SENSOR
HEADLAMP WIPERW/O HEADLAMP WIPER
FRONT PANEL BLANKWITHOUT FRONT BUMPER PLUG
ROOF GLASSWITH FIXED ROOF GLASS
BUMPERFR/RR BUMPER STD BODY-COLOURED
MUDFLAPWITHOUT MUD FLAPS
FRONT FOGLAMPFOG LAMPS WITH CORNERING LIGHT
SPECIAL HEADLAMP (DOUBLE OPTIC)TWO-TONE MASK
SPARE WHEELWITHOUT SPARE WHEEL
EXTERIOR ACCESSORIESCHROME+BODY-COLOURED EXT HANDLE
BUMPER TRIMBRILL BLACK FR BUMPER STRIP + RR NEUTRAL
GLASS (APPEARANCE)FR TINTED WINDOW+DEEPTINTED RR (QUARTER+TAILGATE)
HANDS FREE ACCESS AND STARTINGWITH HANDS-FREE ACCESS/STARTING
Interior Fittings
ANTI-THEFT ALARMWITH THEFT PROTECTION ALARM
CIGAR LIGHTERFRONT CIGAR-LIGHTER
REAR HEAD RESTRAINTREAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINTJOINTED FRONT HEADREST
BLIND SPOT DETECTIONWITHOUT BLIND SPOT MONITORING
FRONT SEATBELTDOUBLE PYROTECHNIC SEAT BELT WITH ALARM
CLIMATE (AMBIENT TEMP)TEMPERATE COUNTRIES
AIR CONDITIONINGWITH AUTO RECIRCULATION HEATER MATRIX
SPEED GRADUATIONSSPEED GRADUATION IN MPH
DRIVING POSITIONRIGHT HAND DRIVE
ADDITIONAL HEATINGWITHOUT ADDITIONNAL HEATING
DASHBOARD EQUIPMENTDASHBOARD + SLUSH VISOR
MISC. INT. LAMPSSOFT AMBIANCE LIGHTING
LOAD SPACE TRIMBOOT CARPET MAT
INSTRUMENT PANEL (CHARACTERISTICS)GRADUATION 260 KM/H 160 M/H COLOUR MATRIX
DOOR TRIMSTANDARD
LOUDSPEAKER4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS
DRIVER SEAT CONTROLDRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROLPASSENGER FRT SEAT MANUAL CNTR
FRONT PASSENGER SEAT ADJUSTMENTPASSENGER TILTING BACK
COMPACT DISCWITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEMWITH NAVIGATION SYSTEM + TRAFFIC INFO
HEADLAMP BULBSHALOGEN BULB
TRAFFIC INFORMATION READERWITHOUT LATERAL TRAJECTORY MONITORING
DISPLAYDISPLAY DG4
CLOCKANALOGUE CLOCK
FOOTRESTDRIVER’S FOOTREST
HEATING ELEMENTNON HEATED SEAT
FRONT LATERAL AIRBAGTHORAX SIDE + CURTAIN AIRBAG
FOOTWELL LIGHTINGDRIVER’S + FRONT PASS’S FOOTWELL LIGHTING
EXTERIOR REAR VIEW MIRROR (HEATED)EXT HEATING REAR VIEW MIRROR
AIRBAG DEACTIVATIONMANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTERREMOTE MANUAL HEADLAMP ADJUSTMENT
DIRECTIONAL HEADLAMPWITHOUT DIRECTIONAL LIGHTS
WIFIWITHOUT WIFI
RADIO RECEIVERRT6 RADIO TEL-DIGITAL REMOTE DISPLAY
REFRIGERATIONAUTOMATIC AIR CONDITIONING
CARPET COVERW/O CARPETMAT
LOAD SPACE STORAGEWITHOUT STORAGE COMPARTMENT IN BOOT
COOLANT LEVEL WARNING LAMPNO WATER LEVEL WARNING
OBSTACLE DETECTION SYSTEMOBSTACLE DETECTOR CAMERA
TRIM ADAPTATIONCHROME KNOB + PVC GAITER
FLOOR MATW/O CARPETMAT
EQUALISER AMPLIFIERWITHOUT EQUALISER AMPLIFIER
RADIO FREQUENCYWESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROLCENTRAL DEADLOCKING + AUTOMATIC LOCKING
STEERING WHEEL4 BRANCH LEATHER STEER WHEEL DECOR METAL
AUDIO PACK AUXILIARY SOCKET1 JACK SOCKET + USB
TELEMATIC UNITWITHOUT TELEMATIC UNIT
Electrical
ALTERNATORALTERNATOR 150 AMP
HORNSHORNS-HARMONY
BATTERYBATTERY L3 720 LDC**************[VIN obfuscated, can be read by forum staff]
STARTER MOTORSTARTER MOTOR CL 5
SPECIAL LIGHTINGAUTOMATIC HEADLAMP ILLUMINATION
CEN. LOCKING REM CONTROL FREQUENCY433.92 MHZ SUPER HETERODYNE
BATTERY CHARGE MEASUREMENTWITH BATTERY CHARGE MEASUREMENT
LIGHTING OF LAMPSAUTOMATIC SWITCHING ON OF LIGHTS
Component Manufacturers
Miscellaneous
SPECIAL SPECIFICATIONSTANDARD
ATMOSPHERIC CONDITIONSNORMAL ATMOSPHERE
VIN PLATEEUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABELWITHOUT LABEL
RADIO HEADPHONE SOCKETWITH ACCESSORIES SOCKET
TRAFFIC SIDEDRIVING ON THE LEFT-HAND SIDE
SIDE IMPACTSSTANDARD SIDE BUMPERS
EMERGENCY EQUIPMENTPUNCTURE REPAIR KIT
SURFACE CONDITIONSGOOD TERRAIN
