List of equipment
- x 5803
Re: List of equipment
We can provide the factory build sheet which lists what it does have equipment wise, i.e. type of gearbox, engine code, engine serial, cruise control, type of Head Unit, etc. paint code, upholstery, parking assistance type, blind spot..... Note that this won't be the same 'customer speak' that you will get in a sales brochure, just the key components.
- Donor 2023
That would be enoughGiveMeABreak wrote: ↑23 Mar 2024, 22:02 We can provide the factory build sheet which lists what it does have equipment wise, i.e. type of gearbox, engine code, engine serial, cruise control, type of Head Unit, etc. paint code, upholstery, parking assistance type, blind spot..... Note that this won't be the same 'customer speak' that you will get in a sales brochure, just the key components.
- x 5803
@Nhokas: Check your email in a minute.
- Donor 2023
Did not received any...
- x 5803
Sent on the 9th April at 16:06. Check your Junk and spam folders.
- Donor 2023
Spam checked but nothing there...GiveMeABreak wrote: ↑18 Apr 2024, 17:34 Sent on the 9th April at 16:06. Check your Junk and spam folders.
- x 5803
Sent again now, using your Forum email, but in case there's still an issue, I've posted it here:
Vehicle characteristics | |
Vehicle family | DS 7 CROSSBACK (X74) |
AS/RP N° | 16419 88 1 0112 |
Warranty Start Date | 06/05/2022 |
Engine serial number | 10 FKBJ 2847340 |
OPB | 00JJ |
BER | e2*2007/46*0601*18 |
P4A | 9833386599 |
General information | |
PRODUCT TYPE | PASSENGER CAR |
COMMERCIAL MARQUE/COMPONENT TYPE | DS |
VEHICLE FAMILY | DS 7 CROSSBACK (X74) |
SILHOUETTE | S.U.V. |
TRIM LEVEL | UPPER MEDIUM |
ENGINE | EP6FADTXHP 1.6L PETROL |
TRANSMISSION | 4X4 8-SPEED AUTOMATIC HYBRID |
PAINT TYPE | METALLIC LACQUER |
BODY COLOUR | EVL - PLATINUM GREY PAINT |
INTERIOR TRIM TYPE | NAPPA LEATHER "4H" |
UPHOLSTERY COLOUR | "FO" |
GEARBOX (CHARACTERISTICS) | EATNG8 |
CONVERSION GUIDANCE | WITHOUT CONVERSION |
DEFINITION TO FOLLOW | INITIALE RANGE |
ENGINE (TYPE) | EP TYPE ENGINE |
OTHER BADGE, " MISC. " | WITHOUT FULLER BADGE |
BADGE | E TENSE 4X4 |
Fuel supply-Engine | |
FUEL SUPPLY | DIRECT EXCHANGER TURBO INJECTION |
FUEL FILLER CAP | WITHOUT FUEL FILLER CAP |
DIESEL FILTER WATER DETECTOR | WITHOUT DIESEL FILTER WATER DETECTOR |
FUEL | UNLEADED PETROL 95 QUALITY A/B/E/E+ |
EMISSIONS STANDARD (ENGINE) | EURO 6.3 ENGINE EMISSION CONTROL |
SPEED SENSOR SIGNAL | FRONT WHEEL SENSOR NON-SIGN RR SIGNED |
CAPACITY | 1600 CM3 |
CATALYTIC CONVERTER | CATALYTIC CONVERTER BELOW 50PPM |
FUEL TANK | PRESSURISED WITH LOCATING TAB |
COOLING MOTOR | RADIATOR EP28 28DM2 BRAZED ALUMINIUM |
CRANKCASE GAS CIRCUIT HEATING | WITH HEATER CASING GAS CIRCUIT |
POWER VARIATION (ENGINE) | ENGINE POWER 147 KW - 300 NM |
SPECIAL POWER TRAIN SOUND | WITHOUT POWER TRAIN ACOUSTICS |
EOBD SELF-DIAGNOSIS SYSTEM | WITH "OBD" AUTO-DIAGNOSTICS |
VEHICLE TECHNICAL DEPOLLUTION | EURO 6.3 VEHICLE TECHNICAL EMISSION CONTROL |
PARTICLE FILTER | WITH PARTICLE EMISSION FILTER |
FAN | VARIABLE SPEED FAN 200W AERO DYNAMIC FLAP |
DRIVE TRAIN | PHEV DRIVE TRAIN |
TANK FILTER | RESERVOIR FILTER INTERIOR |
STOP AND START | WITHOUT STOP AND START |
Gearbox Transmission | |
FINAL DRIVE RATIO | FINAL DRIVE RATIO 15 X 58 |
WHEEL STYLE | STYLE5 20 INCH ALLOY WHEEL |
CLUTCH | WITHOUT CLUTCH |
RIM/TYRE SIZE | 20 INCH TYRE FIT |
TYRE (SIZE, TYPE) | TYRE 235/45 R20 100V NON-REINFORCED |
DRIVING WHEELS | 4 DRIVEN WHEELS |
WHEEL (TYPE) | ALLOY WHEEL ASSEMBLY 1 |
INFLATION PRESSURE LOSS INDICATOR | INDIRECT DETECTION OF UNDER-INFLATION WITH LOCATION |
GEARBOX TYPE | GEARBOX TYPE EATN8 |
Suspension-Steering-Brakes | |
REAR ANTI-ROLL BAR | REAR ANTI-ROLL BAR DIAM 17.5 |
FRONT ANTI-ROLL BAR | FR ANTI-ROLL BAR STIFFNESS 37500 NM/RAD |
BRAKE TYPE | VENTILATED FRONT DISCS/REAR DISCS |
STEERING WHEEL ANGLE | WITH STEERING ANGLE SENSOR |
SUSPENSION | NORMAL SUSPENSION |
DYNAMIC STABILITY CONTROL SYSTEM | ELECTRONIC STABILITY PROGRAM |
BRAKE ASSOCIATED VARIANT | BOSCH 9.3 ESP |
STEERING (OPERATION) | HIGH POWER DOUBLE PINION ELECTRIC POWER STEERING |
PEDAL BRACKET (TYPE) | PEDAL ALUMINIUM |
Body fittings | |
TOWBAR | WITHOUT TOWBAR |
HORNS | HORNS-HARMONY |
SIDE MOULDINGS (TYPE) | CHROME SIDE PROTECTORS |
SIDE MOULDINGS (DIMENSION) | THIN LATERAL/SIDE PROTECTORS+BODY SILL CHROMED DS |
WHEEL EMBELLISHER (STYLE) | BLACK CAP |
EXHAUST TAILPIPE | REAR RIGHT AND LEFT EXHAUST OUTLET |
UNDERBODY SHIELD | DEFLECTOR UNDER FRONT FLOOR |
ADDITIONAL SHIELD (UNDER ENGINE) | W/O ENGINE UNDERSHELDING |
EXT. LOAD RETENTION RING (ATTACHMENT) | WITHOUT DETACHABLE EXTERIOR LASHING RING |
EXT. REARVIEW MIRROR COMP. FUNCTION | DRIVER+PASSENGER ELECTRIC FOLDING+DIODE+MAR+MEMORY+EL |
EXHAUST TAILPIPE TRIM | CHROME EXHAUST OUTLET TRIM |
WINDSCREEN GLASS (TYPE) | HEATED WINDSCREEN GLASS |
WINDSCREEN WIPER | FRONT WIPER BLADE WITH RAIN SENSOR |
HEADLAMP WIPER | W/O HEADLAMP WIPER |
ROOF GLASS | WITH SLIDING TILTING ROOF WINDOW ONE-TOUCH CONTROL ANTI-PINCH |
BUMPER | BODY COLOUR FR BUMPER+GLOSS BLACK GRILLE+BODY COLOUR RR BUMPER+PAINTED BEAD |
NUMBER PLATE | WITHOUT LICENCE PLATE |
FRONT FOGLAMP | LED FOG LAMPS + CORNERING LAMP |
PANORAMIC VISUAL AID | FR PANORAMIC VISUAL ASSISTANCE + RR VISIO PARK 2 |
SPARE WHEEL | WITHOUT SPARE WHEEL |
EXTERIOR ACCESSORIES | CHROME+BODY-COLOURED EXT HANDLE |
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) | CURVED EXTERIOR MIRROR GLASS |
BUMPER TRIM | BUMPER WITHOUT TRIM |
GLASS (APPEARANCE) | TINTED + DARK-TINTED WINDOW GLASS |
WINDOW (TYPE) | ACOUSTIC LAMINATED WINDSCREEN + TOUGHENED REAR GLASS |
HANDS FREE ACCESS AND STARTING | WITH HANDS-FREE ACCESS/STARTING |
Interior fittings | |
ANTI-THEFT ALARM | WITHOUT THEFT PROTECTION ALARM |
CIGAR LIGHTER | WITHOUT CIGAR-LIGHTER |
REAR HEAD RESTRAINT | REAR HEADREST ADJUSTABLE |
FRONT HEAD RESTRAINT | 4-WAY ADJUSTABLE FRONT HEAD RESTRAINT |
REAR SEAT | SEAT CUSHION+BACK 2/3-1/3 FOLDING |
BLIND SPOT DETECTION | WITH BLIND SPOT MONITORING |
REAR SEAT ARMREST | WITH REAR SEAT ARMREST |
CABIN SEAT | WITHOUT CAB SEAT |
LUGGAGE COVER | SHELF |
ASHTRAY | WITHOUT ASHTRAY |
CLIMATE (AMBIENT TEMP) | COLD COUNTRIES |
AIR CONDITIONING | WITH HEATER MATRIX |
SPEED GRADUATIONS | SPEED GRADUATION IN KM/H |
GEAR SELECTOR | RAISED GEAR LEVER AT THE FLOOR + AT THE STEERING WHEEL |
DRIVING POSITION | LEFT-HAND DRIVE |
ADDITIONAL HEATING | WITHOUT ADDITIONNAL HEATING |
MIRROR LINK | WITH MIRROR LINK |
LOAD SPACE LIGHTING | LED STORAGE COMPARTMENT + GLOVE BOX LIGHTING |
DASHBOARD EQUIPMENT | PADDED LEATHER DECOR DASHBOARD |
MISC. INT. LAMPS | POLYCHROME AMBIENCE LED LIGHTING |
INSTRUMENT PANEL (CHARACTERISTICS) | DIGITAL INSTRUMENT PANEL 29 WARNING LAMPS |
CHILD SEAT ANCHORING POINTS | WITHOUT ANCHORAGE WITH ISOFIX FR AND RR |
LOUDSPEAKER | 4 HP FRONT (2 TW + FR) + 4 HP REAR |
ADDITIONAL BLOWER | WITH ADDITIONAL PULSE |
POLLEN FILTER | WITH POLLEN FILTER + ACTIVATED CARBON |
FRONT PASSENGER SEAT HEIGHT CONTROL | FRONT PASSENGER SEAT HEIGHT ADJUSTER ELECTRIC HEIGHT ADJUSTMENT+ELECTRIC FRONT SEAT CUSHION ANGLE |
DRIVER SEAT CONTROL | DRIVER’S SEAT WITH MEMORY CONTROL+CUSHION FRONT ADJUSTMENT |
FRONT PASSENGER SEAT CONTROL | PASSENGER’S FR ELEC SEAT CTRL + CUSHION FRONT ADJ |
DRIVER SEAT ADJUSTMENT | DRIVER’S SEAT TILTING BACK ELECPNE LUMBAR SUPPORT+MEMO |
FRONT PASSENGER SEAT ADJUSTMENT | TILTING SEAT BACK ELECTROPNEUMATIC LUMBAR SUPPORT+MEMO |
FRONT SEAT ARMREST | FRONT CENTRAL ARMREST FLOCKED + LEATHER |
COMPACT DISC | WITHOUT COMPACT DISC |
SATELLITE NAVIGATION SYSTEM | WITH NAVIGATION SYSTEM COLOUR SCREEN |
HEADLAMP BULBS | LED BULB |
TRAFFIC INFORMATION READER | PREVENTION+TRAJECTORY CENTRING LPA |
DISPLAY | DGT TOUCHSCREEN+12" DFT DISPLAY |
CLOCK | ANALOGUE CLOCK |
COURTESY MIRROR | DRIVER+PASSENGER CONCEALABLE MIRROR WITH LED LIGHTING |
FOOTREST | ALU DRIVER’S FOOTREST |
OIL GAUGE | STD OIL LEVEL INDICATOR |
HEATING ELEMENT | DRIVER AND PASSENGER HEATED + VENTILATED SEAT ROW 1 |
FRONT LATERAL AIRBAG | FR CHEST/PELVIS SIDE AIRBAG+CURTAIN AIRBAG |
FOOTWELL LIGHTING | DRIVER + FR PASSENGER FOOTWELL LIGHTING |
REAR PASSENGER PROTECTION | W/O RR PASSENGER PROTECTION |
AIRBAG DEACTIVATION | MANUAL AIRBAG DEACTIVATION |
HEADLAMP HEIGHT ADJUSTER | AUTOMATIC HEADLAMP ADJUSTMENT |
WIFI | WITH WIFI |
RADIO RECEIVER | DIGITAL CONNECTED NAVIGATION |
REFRIGERATION | AUTOMATIC AIR CONDITIONING |
CRUISE CONTROL | SPEED LIMITER ACC STOP AND GO REGULATOR |
DRIVER’S SEAT HEIGHT CONTROL | ELECTRIC CONTRL DRIVERS HEIGHT ADJ |
INTERIOR REAR VIEW MIRROR | FRAMELESS INTERIOR ELECTROCHROMATIC MIRROR |
CARPET COVER | CARPET MAT 1 |
LOAD SPACE STORAGE | RETRACTABLE FLOOR STORAGE COMPARTMENT |
REAR SEAT PADDING | WITHOUT RR PASSENGER DETECTION |
TUNER RADIO | TRI RADIO TUNER |
OBSTACLE DETECTION SYSTEM | FRONT-REAR RADAR OBSTACLE SENSOR |
TRIM ADAPTATION | LEATHER GEAR LEVER KNOB + LEATHER GAITER |
FLOOR MAT | FR + RR MATS |
EQUALISER AMPLIFIER | AMPLI EQUALISER WITH PREMIUM 12 CHANNELS |
RADIO FREQUENCY | WESTERN EUROPE RADIO FREQUENCY |
LOCKING CONTROL | NORMAL + AUTOMATIC LOCKING |
STEERING WHEEL | SPLIT LEATHER STEERING WHEEL + DECOR |
SEATING ASSOCIATED VARIANT | VARIANT ASSOCIATED WITH HIGH SEAT POSITION |
AUDIO PACK AUXILIARY SOCKET | 3 USB PORTS |
TELEMATIC UNIT | INDEPENDENT TELEMATIC UNIT 3S |
Electrical | |
ALTERNATOR | ISTT60 |
BATTERY | L2 680 60AH EFR 680 BATTERY BECOMES EF |
STARTER MOTOR | WITHOUT STARTER MOTOR |
CEN. LOCKING REM CONTROL FREQUENCY | 433.92 MHZ SUPER HETERODYNE |
ELECTRICAL EQUIPMENT (SUPPLY) | STANDARD PROVISION ELECTRICAL EQUIPMENT |
BATTERY CHARGER | SINGLE-PHASE 7 KW ON-BOARD CHARGER |
MULTIPLEXING | R3 INT ELECTRICAL ARCHITECTURE |
ELECTRIC VEHICLE CHARGING PLUG | T2 CABLE SOCKET E/F |
BATTERY CHARGE MEASUREMENT | WITH BATTERY CHARGE MEASUREMENT |
LIGHTING OF LAMPS | AUTOMATIC SWITCHING ON OF THE LIGHTS+AUTOMATIC SWITCHING |
Component manufacturers | |
Miscellaneous | |
SPECIAL SPECIFICATION | STANDARD |
CONDENSER (SPECIFICATIONS) | CONDENSER 23,5DM2 THICKNESS 16 |
ATMOSPHERIC CONDITIONS | NORMAL ATMOSPHERE |
VIN PLATE | EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE |
LABEL | WITHOUT LABEL |
AIR CONDITIONING PIPES | STANDARD AIR CONDITIONING PIPES |
RADIO HEADPHONE SOCKET | DOUBLE ACCESSORY SOCKET |
SET OF KEYS | SET OF BADGE KEYS + BACK-UP KEY |
REFRIGERANT | AIRCON FLUID 1234 YF |
EMERGENCY EQUIPMENT | PUNCTURE REPAIR KIT |
SURFACE CONDITIONS | GOOD TERRAIN |
EMERGENCY WARNING TRIANGLE | WITHOUT WARNING TRIANGLE |
