Manual Transmission Service (ML6C) Peugeot Expert 2.0L Hdi
Mr_Expertise
Post by Mr_Expertise »
Hi,
New Peugeot owner, first time poster. Im changing the front left drive shaft on my Peugeot Expert and as such will be needing to refill the transmission fluid.
I assume most of the oil will drain out when i remove the drive shaft or will i actually need to drain the transmission fully from the plug?
If so then i wonder about the size of the copper washer for the drain plug? Is it: 22mm outer diameter, 16mm, inner diameter, 2mm thickness? Is there a torque setting for the transmission plug?
I will also be putting in a new drive shaft seal and i wonder whether anyone could confirm that i have the right one for the left hand side:
1623179580:
Diamètre extérieur 1 [mm] : 40
Diamètre extérieur 2 [mm] : 58
Largeur [mm] : 11,3
I will be refilling with 1.9L of 75W80 PSA B712330 as it is the reinforced gearbox (2015 model) If i understand correctly there is no oil level check hole and i just fill it back up through the breather hole.
I would appreciate if someone could let me know if that all looks to be correct!
Thanks in advance
Cisco
Re: Manual Transmission Service (ML6C) Peugeot Expert 2.0L Hdi
Post by Cisco »
Hi,
Can I ask you how it went? I also need to drain the trans and was wondering about the washer size and fluid choice
