Dear all,
I am first time in this Forum and I would like to say "Hi" to everybody.
I have problem with my Peugeot 3008 1.6Hdi GT 2017 95k km on clock. When I turn on heating on HI on both sides, hot air is going out from driver side vent, but from passenger side is like max 18C degree .
Kindly asking you for any suggestion. Do I have maybe warranty (since is less then 100 000km, car is from Sweden and I am living in Sweden) ?
Thank you for any help
Peugeot 3008 Heater Issue
- x 1292
Re: Peugeot 3008 Heater Issue
Welcome along! I've split this off into its own topic.
On the MK2 C4 Picasso, which shares a lot with the the 3008, blockage of the heater matrix is common causing a loss of heat to the RH side of the car (so driver's side in the UK!). I suspect this is your issue. The matrix is not very expensive, and not too hard to change (although more difficult on a LHD car, you may need to remove the steering column). Unlikely there is any warranty from Peugeot, but if you've recently bought it, then there may be a warranty from the supplier - there would be in the UK.
Hi Richard, thank you very much.
I am pretty sure that C4 MK2 and 3008 have probably 1/1 same HVAC system.
What you meaning when you say heater matrix? Radiator ? I was "google" little bit and looks like actuator for "flaps" . It will be great if you can share any picture.
I bought car almost year ago, so unfortunately I don't have supplier warranty :/ .
Thank you for answer.
- x 1292
Matrix is the radiator inside the car. It might be a flap problem, but if you can vary the heat between cold and slightly warm, then it's more likely to be the heater matrix.
Hallo there what was the outcome of this, i have the same problem on my 5008.
And its a LHD car.
Regards Kenneth
And its a LHD car.
Regards Kenneth
Hi All and Happy New year,
I experienced similar issue with my 3008 2019 BlueHDI 180 GT. I was on a long journey, temperature outside was around 2°C and inside was set to 23°C. Passenger side (LHS) was ok but driver side the airflow was only slightly warm from all the vents. I tried to switch direction and close and open vents but still the same. I read on forums that it's known issue in 3008 and C4 and it's heating matrix issue. Is there any way to confirm it is the matrix causing the issue before I start any repairs(Diagbox or any other method)?
TIA
TIA
Today I have replaced the radiator and everything is working perfectly. Heating on both sides is good now.
