Stellantis Recommended Engine Oils Updated February 2024
x 6963
Article Updated to Reflect Changes to Specifications and Oils from February 2024
How To Use This Guide:
First, lookup the Code for the country your vehicle is being used in from the Country Tables. Next, scroll down until you find the tables for your Country (A, B, C or D). Next, cross reference your vehicle's Engine Code in the tables listed to determine the correct grade and specification.
Note: Some engines have a build date (RPO) code which will affect the oil specification, e.g. the DV5 Diesel engines for example.
An Engine Oil is Defined by:
  • A Grade
  • An Approval according to specs. laid down by the ACEA
  • One or more approvals in accordance with Manufacturer's Specifications / Recommendations
Grade of Engine Oil
The grade of the engine Oil is defined by the standards of the SAE (Society of Automotive Engineers).
The Grade of an Engine Oil is Represented by XX W XX
Key
  1. Figure or number corresponding to the cold grade of the engine oil (the small the number, the easy cold starting will be).
  2. Letter W for winter.
  3. Number indicating the hot grade of engine oil (the higher the number, the more the engine oil will resist high temperatures and remain viscous).
An engine oil is developed to perform well over a wide temperature range (0W30 applicable between -45 and 45°C)).
An engine Oil is developed to be highly efficient over a considerable temperature range (for example: 0W30 applicable between -45 and 45°C).
Note: The grade of an engine oil is not linked to its performance against aging, clogging and wear.
Example: A 5W30 Oil is not necessarily more effective than an 0W30 Oil and vice versa.
Technical specifications of the ACEA standards
The ACEA standards indicate minimum Oil performance. The requirements imposed do not correspond to the Oil performances recommended by PEUGEOT / CITROEN / DS / OPEL / VAUXHALL. These standards are only a basis for performance.
NOTE: The specifications of the ACEA (European Automobile Manufacturers Association) standards do not meet the requirements of PEUGEOT / CITROEN / DS / OPEL / VAUXHALL.
-Performance with ageingEngine protectionPerformance relating to CO2Post-processing compatibility,
EURO 6 Emission Control Standard
ACEA A3 / B4+ ++ +--
ACEA C2, C3 or C4++++
ACEA C5+++ ++
PEUGEOT/CITROËN/DS requirements+ + ++ + ++ + ++ + +
Key
  • +: Medium
  • + +: Correct
  • + + +: Very good
PEUGEOT/CITROËN/DS/OPEL/VAUXHALL Recommendations
Exclusive use of one of the following Oils:
  • The TOTAL Oils listed in the table below
  • All other Oils complying with PEUGEOT/CITROËN/DS standards (Refer to the recommendations tables)
The oils recommended by PEUGEOT/CITROËN/DS/OPEL/VAUXHALL standards have characteristics that are superior to the oils defined by ACEA standards.
CAUTION: The use of additives in engine Oil is strictly prohibited.
Petrol and Diesel Engines
Recommended oil (*)PEUGEOT / CITROËN / DS standards
QUARTZ INEO XTRA FIRST 0W20B71 2010
QUARTZ INEO FIRST 0W30B71 2312 / B71 2302
D-XITY PCI ECO 0W30
QUARTZ INEO ECS 5W30B71 2290
QUARTZ INEO HTC 5W30
QUARTZ INEO RCP 5W30
DPCA 5W30 ECS
D-XITY AMQ ECO 5W30
QUARTZ INEO HTC 5W30B71 2297
DPCA 5W30 HTC
QUARTZ INEO RCP 5W30FPW9.55535/03
QUARTZ 9000 5W40B71 2296
QUARTZ 9000 DIESEL 5W40
QUARTZ 9000 ESSENCE 5W40
DPCA 5W40
D-XITY AMQ 5W40
QUARTZ 7000 10W40B71 2300
QUARTZ 7000 DIESEL 10W40
QUARTZ 7000 ESSENCE 10W40
QUARTZ 7000 S 10W40
QUARTZ 7000 DIESEL S 10W40
(*) Or any other lubricant complying with PEUGEOT/CITROËN/DS/OPEL/VAUXHALL standards
Identification of the Engine Specifications
"d" Vehicle family.
"e" Body style.
"f" Engine (Legislative code).
  • Note the country in which the vehicle is used (Group "A", "B" or "C" in the tables below)
  • Identify the engine legislative code on the vehicle Identification plate (At "f")
  • Make a note of the engine legislative code
  • Refer to the section "Presentation of country groupings" and then the section "Oil recommendations per group of countries"
Country Groupings
All countries are grouped into 4 groups of countries:
  • Unit A: Temperate or cold countries / Europe fuel types (not sulphur)
  • Unit B: Countries Outside Europe
  • Unit C: Argentina / Brazil
  • Unit D: China
Unit A: Temperate or Cold Countries / Europe Fuel Types (not sulphur)
List of countries affectedList of countries affectedList of countries affectedList of countries affected
AlbaniaSpainKazakhstanPortugal
GermanyEstoniaKosovoCzech Republic
AustriaFinlandLatviaRoumania
AzerbaïdjanFranceLithuaniaRussia
BelgiumGeorgiaLuxembourgSerbia
BelorussiaGreat BritainMacedoniaSlovakia
Bosnia-HerzegovinaGreeceMaltaSlovenia
BulgariaHungaryMoldaviaSweden
CanadaCanary IslesMontenegroSwitzerland
CyprusIrelandNorwayUkraine
KoreaIcelandNew Zealand-
CroatiaItalyNetherlands-
DenmarkJapanPoland-
AfghanistanUnited StatesMacaoSaint Martin
South AfricaEthiopiaMadagascarSão Tomé and Príncipe
AlgeriaFijiMalaysiaSaint Vincent and the Grenadines
AngolaGabonMalawiSaint Lucia
Antigua and BarbudaGambiaMaliSamoa
Saudi ArabiaGhanaMoroccoSenegal
ArmeniaGrenadaMartiniqueSeychelles
ArubaGuadeloupeMauritaniaSingapore
AustraliaGuamMayotteSomalia
BahamasGuatemalaMexicoSudan
BahrainGuineaMongoliaSri Lanka
BangladeshGuinea-BissauMozambiqueSurinam
BarbadosEquatorial GuineaNamibiaSwaziland
BelizeGuyanaNepalSyria
BeninFrench GuianaNicaraguaTadjikistan
BermudaHaitiNigerTaiwan
BhutanHawaiiNigeriaTanzania
BoliviaHondurasNew CaledoniaChad
BotswanaHong KongOmanThailand
BruneiCayman IslandsUgandaEast Timor
Burkina FasoReunion IslandUzbekistanTogo
BurundiMariana IslandsPakistanTonga
CambodiaMauritiusPalestineTrinidad and Tobago
CameroonVirgin IslandsPanamaTunisia
Cape VerdeIndiaPapua New GuineaTurkmenistan
Central African RepublicIndonesiaParaguayTurkey
ChileIraqPeruUnion of Myanmar
ColumbiaIranPhilippinesUruguay
ComoresIsraelFrench PolynesiaVanuatu
Costa RicaJamaicaPuerto RicoVenezuela
Ivory CoastJordanQatarVietnam
CubaKenyaDemocratic Republic of CongoYemen
CuracaoKirghizistanLao People’s Democratic RepublicZambia
DjiboutiKuwaitDominican RepublicZimbabwe
EgyptLesothoRepublic of the Congo-
El SalvadorLebanonBritish Solomon Islands-
United Arab EmiratesLiberiaRwanda-
EcuadorLibyaSaint Kitts and Nevis-
Unit C: Argentina / Brazil / Chile
ArgentinaBrazilChile
Unit D: China
China
Oil Recommendations per Group of Countries
Unit A: Temperate or Cold Countries - Europe Fuel Types (not sulphur)
CAUTION: Category ACEA 5W30 C2, 0W30 C1 / C2 Oil must not be used in engines earlier than 2000 (July 1999) model year. The use of additives in engine Oil is strictly prohibited.
TU / ET Engines.
Engine TypeEngine Identification0W30 Oil
B71 2312
5W30 Oil
B71 2290
5W40 Oil
B71 2296
10W40 Oil
B71 2300
TU1 / TU1AHFX / HFY / HFZ / HFVOKOKOKOK
TU3 / ET3 / TU3AKFW / KFV / K6D / K6E / KFU /
K6F / KFX / K6C / KFS / KFT
OKOKOKOK
TU5NFV / NFS / NFU / N6A /
NFT / N6B / NFR
OKOKOKOK
EW Engines.
Engine TypeEngine Identification5W30 Oil
B71 2290
5W40 Oil
B71 2296
10W40 Oil
B71 2300
EW7A6FY-OKOK
EW7J46FZOKOKOK
EW10ARFJ / RFH-OK-
EW10J4RFN / RFM / RFP / RFROKOKOK
EW10J4SRFK-OK-
EW12E43FY-OKOK
EW12J43FZ-OKOK
TOYOTA Engines.
B71 2312
5W30 Oil
B71 2290
5W40 Oil
B71 2296
10W40 Oil
B71 2300
384FCFA / CFBOKOKOKOK
1KR-FECFB-OK-OK
MITSUBISHI Engines.
Engine typeEngine Identification0W20 oil
B71 2010
0W30 oil
B71 2312
5W30 oil
B71 2290
5W40 oil
B71 2296
10W40 oil
B71 2300
2.4 MMCSFZ / SFY-OKOKOKOK
2.0 MMCAFZ / AFX / FZ9 / FZP / AFY / FZC / FZH / FZE / FZF-OKOKOKOK
1.8 D MMC6HZ / 6HY-OKOK--
1.6 MMCNKZ-OKOKOKOK
4K22TNKZOKOK---
EP Engines.
B71 2010
0W30 oil
B71 2312
5W30 oil
B71 2290
EP38FS-OKOK
EP3C8FP / 8FR / 8FN-OKOK
EP65FW / 5FP-OKOK
EP6C5FS / 5FK / 5FL / 5FJ / 5FH-OKOK
EP6CDT5FN / 5FV / 5F2 / 5FA-OK-
EP6CDTX5FU / 5FB-OK-
EP6CDT M5FE / 5FC / 5FM-OK-
EP6CDTR5FG-OK-
EP6DT5FX / 5FT / 5FR / 5F4-OK-
EP6DTS5FY / 5FF / 5FD-OK-
EP6FADTXD5GF-OK-
EP6FADTREGX-OK-
EP6FADTX5GG-OK-
EP6FADTX HP5GB-OK-
EP6FDT5GZ / 5GW / 5GL-OK-
EP6FDT M5GY / 5GX / 5GV-OK-
EP6FDTX5GR / 5GM / 5GT-OK-
EP6FDTR5GN / 5GP-OK-
EP6LTC / EP6LTCHDGC / DGROK--
EB Engines.
B71 2010
0W30 oil
B71 2312
5W30 oil
B71 2290
5W40 oil
B71 2296
EB0ZMZ-OKOKOK
EB2HMX / HMW / HMZ / HMT / HMU-OKOKOK
EB2 FFHMZ-OK--
EB2 MHMY-OKOKOK
EB2ADTHNC / HNE / HNP / HNKOK---
EB2ADT MHN7 / HNB / HNMOK---
EB2ADTSHNSOK---
EB2ADTS MHNLOK---
EB2ADTXHNJ / HNNOK---
EB2DTSHNY-OK--
EB2DTS MHNW-OK--
EB2DTHNZ-OK--
EB2DT MHNV-OK--
EB2FA / EB2FADHMR / HMM / HMHOK---
EB2FA FFHMN-OK--
EB2FA FKHMF-OK-OK
EB2FA MHMJ-OK--
EB2FA MKHMG-OK-OK
EB2LTDTBDOK---
EC Engine.
B71 2312
5W30 Oil
B71 2290
5W40 Oil
B71 2296
10W40 Oil
B71 2300
EC5NFPOKOKOKOK
EC5 (E100)NFNOK---
DV Engines.
B71 2010
0W30 oil
B71 2312
5W30 oil
FPW9.55535/03
5W30 oil
B71 2290
5W40 oil
B71 2296
10W40 oil
B71 2300
DV4C8HR / 8HP-OK-OK--
DV4TD8HT / 8HZ / 8HX-OK-OKOKOK
DV4TED8HS-OK-OKOKOK
DV4TED48HV / 8HY-OK-OKOKOK
DV5RC / DV5RD / DV5RE / DV5RUC / DV5RUDPrior to RPO No. 16885YHX / YHY / YHZ / YHW / YHV / YHR--OK---
DV5RC / DV5RD / DV5RE / DV5RUC / DV5RUDFrom RPO No. 16886YHX / YHY / YHZ / YHW / YHV / YHROK-----
DV6ATED4 / DV6AUTED49HX-OK-OKOKOK
DV6BTED4 / DV6BUTED49HW / 9HT-OK-OKOKOK
DV6C / DV6UC9HR / 9HC / 9HM / 9HL / 9HD-OK-OK--
DV6C M9HG-OK--OK-
DV6D9HP / 9HF-OK-OK--
DV6D M9HE / 9HJ-OK--OK-
DV6DU M9HH-OK--OK-
DV6E9HN-OK-OK--
DV6E M9HK-OK--OK-
DV6FCBHZ-OK----
DV6FCUBHX-OK----
DV6FDBHY-OK----
DV6FDUBHV / BHS-OK----
DF6FEBHW-OK----
DV6TED49HY-OK-OKOKOK
DV6TED4
(with particle filter)
9HZ-OK-OKOKOK
DV6TED4B ( with particle filter)9HV-OK-OKOKOK
DV6TED4BU ( with particle filter)9HS-OK-OKOKOK
DV6UTED49HU-OK-OKOKOK
DW Engines.
B71 2312
5W30 Oil
B71 2290
5W40 Oil
B71 2296
10W40 Oil
B71 2300
DW8WJZ-OKOKOK
DW8BWJY / WJX-OKOKOK
DW10ATEDRHZ-OKOKOK
DW10ATED
RHS-OKOKOK
DW10ATED4RHW-OKOKOK
DW10ATED4
RHT / RHM-OKOKOK
DW10BTEDRHX-OKOKOK
DW10BTED4
RHR / RHL / RHJ-OKOKOK
DW10BTED4
Euro 5 Emission Control Standard
RHF-OKOK-
DW10CTED4RHE / RHH / RHD / AHY / AHZ / RHB / RHC / RHAOKOK--
DW10FCAHW / AHH / EHZ / EHY-OK--
DW10FDAHX / AHV / AHR / AHS / AHFOK---
DW10FEAHJ / AHK / AHDOK---
DW10FUAHP / AHN / AHMOK
DW10TDRHY / RHV / RHU-OKOKOK
DW10UTED4RHK-OKOKOK
DW10UTED4
RHG-OKOKOK
DW12BTED4
4HP / 4HR / 4HS / 4HT-OKOKOK
DW12C4HLOKOK--
DW12MTED4
4HN-OKOKOK
DW12RU4HH / 4HJ / 4HKOK---
DW12TED4
4HW / 4HX / 4HZ-OKOKOK
DW12UTED4HY-OKOKOK
DT Engines.
B71 2312
5W30 Oil
B71 2290
5W40 Oil
B71 2296
10W40 Oil
B71 2300
DT17UHZ-OKOKOK
DT20X8ZOKOK--
PUMA Engines.
B71 2312
5W30 Oil
B71 2290
5W40 Oil
B71 2296
10W40 Oil
B71 2300
PUMA
(Euro 4 Emission Control Standard)
4HV / 4HU /
4HM / MFB
-OKOKOK
PUMA C4HG / 4HH /
4HJ / 4HF
OKOK--
SOFIM Engines.
B71 2312
5W30 Oil
B71 2290
5W40 Oil
B71 2296
10W40 Oil
B71 2300
F28DT8140.43S / 8040.23-OKOKOK
F28DTGV8140.43 N-OKOKOK
F30DTEF1CE0481D / F1CE3481DM-OKOKOK
F30DTEF1CE348IN / D / EOKOK--
FIAT Engine.
B71 2312
5W30 Oil
B71 2290
1.3 HDi 75FHZOKOK
YUNNEI Engine.
Engine typeEngine Identification0W30 oil
B71 2312
5W30 oil
B71 2290
D20TFHZ-OK
Note: Category ACEA 5W30 C2 , 0W30 C1 / C2 oil must not be used in engines earlier than 2000 (7/99) model year. The use of additives in engine oil is strictly prohibited.
TU / ET Engines.
Engine typeEngine Identification5W30 oil
B71 2297
5W40 oil
B71 2296
TU3 / ET3 / TU3AKFW / KFV / K6D / K6E / KFU / K6F / KFX / K6C / KFS / KFTOKOK
TU4 MYFZOK-
TU5NFV / NFS / NFU / N6A / NFT / N6B / NFROKOK
EW Engines.
B71 2297
5W40 oil
B71 2296
EW7A6FY-OK
EW7J46FZOKOK
EW10ARFJ / RFH-OK
EW10J4SRFK-OK
EW12E43FY-OK
EW12J43FZ-OK
TOYOTA Engines.
B71 2297
5W40 oil
B71 2296
384FCFA / CFBOKOK
1KR-FECFBOK-
MITSUBISHI Engines.
B71 2297
5W40 oil
B71 2296
2.4 MMCSFZ / SFYOKOK
2.0 MMCAFZ / AFX / FZ9 / FZP / AFY / FZC / FZH / FZE / FZFOKOK
1.8 D MMC6HZ / 6HYOK-
1.6 MMCNKZOKOK
4K22TTGTOK-
EP Engines.
B71 2297
EP38FSOK
EP3C8FP / 8FR / 8FNOK
EP65FW / 5FPOK
EP6C5FS / 5FK / 5FL / 5FJ / 5FHOK
EP6CDT5FN / 5FV / 5F2 / 5FAOK
EP6CDTX5FU / 5FBOK
EP6CDT M5FE / 5FC / 5FMOK
EP6CDTR5FGOK
EP6DT5FX / 5FT / 5FR / 5F4OK
EP6DTS5FY / 5FF / 5FDOK
EP6FADTXD5GFOK
EP6FADTX5GGOK
EP6FADTX HP5GBOK
EP6FDT5GZ / 5GW / 5GLOK
EP6FDT M5GY / 5GX / 5GVOK
EP6FDTX5GR / 5GM / 5GTOK
EP6FDTR5GN / 5GPOK
EP6LTC MDGPOK
EB Engines.
B71 2297
5W40 oil
B71 2296
EB0ZMZOKOK
EB2HMX / HMW / HMZ / HMT / HMUOKOK
EB2 FFHMZOK-
EB2 MHMYOKOK
EB2ADTSHNSOK-
EB2ADTS MHNLOK-
EB2ADTS-CHNTOK-
EB2ADTXHNJ / HNNOK-
EB2DTHNZOK-
EB2DT MHNVOK-
EB2DTSHNYOK-
EB2DTS MHNWOK-
EB2A FFHMNOK-
EB2FA FKHMFOKOK
EB2FA MHMJOK-
EB2FA MKHMGOKOK
EB2LTDTBDOK-
EC Engine.
B71 2297
5W40 oil
B71 2296
EC5NFPOKOK
EC5 (E100)NFNOK-
EC8WFZOK-
DV Engines.
B71 2297
5W40 oil
B71 2296
DV4C8HR / 8HPOK-
DV4TD8HT / 8HZ / 8HXOKOK
DV4TED8HSOKOK
DV4TED48HV / 8HYOKOK
DV5RCYHX / YHZOK-
DV5RDYHYOK-
DV5RUCYHVOK-
DV5RUC DYHROK-
DV6ATED4 / DV6AUTED49HXOKOK
DV6BTED4 / DV6BUTED49HW / 9HTOKOK
DV6C / DV6UC9HR / 9HC / 9HM / 9HL / 9HDOK-
DV6C M9HGOKOK
DV6D9HP / 9HFOK-
DV6D M9HE / 9HJOKOK
DV6DU M9HHOKOK
DV6E9HNOK-
DV6E M9HKOKOK
DV6FCBHZOK-
DV6FCUBHXOK-
DV6FDBHYOK-
DV6FDUBHV / BHSOK-
DV6FEBHWOK-
DV6TED49HYOKOK
DV6TED4 / DV6TED4B / DV6TED4BU
9HZ / 9HV / 9HSOKOK
DV6UTED49HUOKOK
DW Engines.
B71 2297
5W40 oil
B71 2296
DW8WJZOKOK
DW8BWJY / WJXOKOK
DW10ATEDRHZOKOK
DW10ATED (with particle filter)RHSOKOK
DW10ATED4RHWOKOK
DW10ATED4 (with particle filter)RHT / RHMOKOK
DW10BTEDRHXOKOK
DW10BTED4
RHR / RHL / RHJOKOK
DW10BTED4
(with particle filter) Euro 5 emission control standard
RHFOKOK
DW10CTED4RHE / RHH / RHD / AHY / AHZ / RHB / RHC / RHAOK-
DW10FCAHW / AHH / EHZ / EHYOK-
DW10FUAHP / AHN / AHMOK-
DW10TDRHY / RHV / RHUOKOK
DW10UTED4RHKOKOK
DW10UTED4
RHGOKOK
DW12BTED4
4HP / 4HR / 4HS / 4HTOKOK
DW12C4HLOK-
DW12MTED4
4HNOKOK
DW12RL4HY / 4HZOK-
DW12TED4
4HW / 4HX / 4HZOKOK
DW12UTED4HYOKOK
DT Engines.
B71 2297
5W40 oil
B71 2296
DT17UHZ-OK
DT20X8ZOK-
PUMA Engines.
B71 2297
5W40 oil
B71 2296
PUMA
(Euro 4 emission control standard)
4HV / 4HU / 4HM / MFB-OK
PUMA C4HG / 4HH / 4HJ / 4HFOK-
SOFIM Engines.
B71 2297
5W40 oil
B71 2296
F28DTGV8140.43 N-OK
F30DTEF1CE348IN / D / EOK-
FIAT Engine.
B71 2297
1.3 HDi 75FHZOK
YUNNEI Engine.
B71 2297
D20T-OK
Note: Category ACEA 5W30 C2 , 0W30 C1 / C2 Oil must not be used in engines earlier than 2000 (07/1999) model year. The use of additives in engine Oil is strictly prohibited.
TU / ET Engines.
B71 2302
5W30 oil
B71 2297
5W40 oil
B71 2296
10W40 oil
B71 2300
TU3 / ET3 / TU3AKFW / KFV / K6D / K6E / KFU / K6F / KFX / K6C / KFS / KFTOKOKOKOK
TU4 MYFZ-OK-OK
TU4 FFYZY-OK--
TU5NFV / NFS / NFU / N6A / NFT / N6B / NFROKOKOKOK
EW Engines.
B71 2297
5W40 oil
B71 2296
10W40 oil
B71 2300
EW7A6FY-OKOK
EW7J46FZOKOKOK
EW10ARFJ / RFH-OKOK
EW10J4SRFK-OK-
EW12E43FY-OKOK
EW12J43FZ-OKOK
TOYOTA Engines.
B71 2302
5W30 oil
B71 2297
5W40 oil
B71 2296
10W40 oil
B71 2300
1KR-FECFB-OK-OK
MITSUBISHI Engines.
B71 2302
5W30 oil
B71 2297
5W40 oil
B71 2296
10W40 oil
B71 2300
2.4 MMCSFZ / SFYOKOKOKOK
2.0 MMCAFZ / AFX / FZ9 / FZP / AFY / FZC / FZH / FZE / FZFOKOKOKOK
1.8 D MMC6HZ / 6HYOKOK--
1.6 MMCNKZOKOKOKOK
4K22T--OK--
EP Engines.
B71 2302
5W30 oil
B71 2297
EP38FSOKOK
EP3C8FP / 8FR / 8FNOKOK
EP65FW / 5FPOKOK
EP6C5FS / 5FK / 5FL / 5FJ / 5FHOKOK
EP6CDTX5FU / 5FB-OK
EP6CDTR5FG-OK
EP6DT5FX / 5FT / 5FR / 5F4OKOK
EP6DTS5FY / 5FF / 5FDOKOK
EP6FADTXD5GFOKOK
EP6FADTX5GGOKOK
EP6FADTX HP5GBOKOK
EP6FDT5GZ / 5GW / 5GLOKOK
EP6FDT M5GY / 5GX / 5GVOKOK
EP6FDTX5GR / 5GM / 5GTOKOK
EP6FDTR5GN / 5GPOKOK
EP6LTDTBDOKOK
EB Engines.
B71 2302
5W30 oil
B71 2297
5W40 oil
B71 2296
EB0ZMZOKOKOK
EB2HMX / HMW / HMZ / HMT / HMUOKOKOK
EB2 FFHMZOKOK-
EB2 MHMYOKOKOK
EB2ADTHNC / HNE / HNP / HMKOKOK-
EB2ADT MHN7 / HNB / HNMOKOK-
EB2ADT SHNSOKOK-
EB2ADTS MHNLOKOK-
EB2ADTS CHNTOKOK-
EB2ADTXHNJ / HNNOKOK-
EB2DTHNZOKOK-
EB2DT MHNVOKOK-
EB2DTSHNYOKOK-
EB2DTS MHNWOKOK-
EB2A FFHMNOKOK-
EB2FA / EB2FADHMR / HMM / HMHOKOK-
EB2A FKHMFOKOKOK
EB2FA MHMJOKOK-
EB2FA MKHMGOKOKOK
EB2LTDTBDOKOK-
EC Engine.
B71 2302
5W30 oil B71 22975W40 oil
B71 2296
10W40 oil
B71 2300
EC5NFPOKOKOKOK
EC5 (E100)NFNOKOK--
EC8-OKOK--
DV Engines.
B71 2302
5W30 oil
B71 2297
DV4C8HR / 8HPOKOK
DV4TED8HSOKOK
DV5RCYHX / YHZOKOK
DV5RDYHYOKOK
DV5RUCYHVOKOK
DV5RUC DYHROKOK
DV5REYHWOKOK
DV6C / DV6UC9HR / 9HC / 9HM / 9HL / 9HDOKOK
DV6C M9HGOKOK
DV6D9HP / 9HFOKOK
DV6D M9HE / 9HJOKOK
DV6DU M9HHOKOK
DV6E9HNOKOK
DV6E M9HKOKOK
DV6FCBHZOKOK
DV6FCUBHXOKOK
DV6FDBHYOKOK
DV6FDUBHV / BHSOKOK
DF6FEBHWOKOK
DV6TED49HYOKOK
9HZ / 9HV / 9HSOKOK
DV6UTED49HUOKOK
DW Engines.
B71 2302
5W30 oil
B71 2297
DW8WJZOKOK
DW8BWJY / WJXOKOK
DW10ATEDRHZOKOK
DW10ATED
RHSOKOK
DW10ATED4RHWOKOK
DW10ATED4
RHT / RHMOKOK
DW10BTEDRHXOKOK
DW10BTED4
RHR / RHL / RHJOKOK
DW10BTED4
RHFOKOK
DW10UTED4RHKOKOK
DW10UTED4
RHGOKOK
DW12BTED4
DW12C4HLOK-
DW12MTED4
4HNOKOK
DW12RU4HH / 4HJ / 4HKOKOK
DW12RL4HY / 4HZ-OK
DW12TED4
4HW / 4HX / 4HZOKOK
DW12UTED4HYOKOK
Engine typeEngine Identification0W30 oil B71 23025W30 oil B71 22975W40 oil B71 2296
DW10FCAHW / AHH / EHZ / EHYOKOK-
DW10FUAHP / AHN / AHMOKOK-
DT Engines.
B71 2302
5W30 oil
B71 2297
5W40 oil
B71 2296
10W40 oil
B71 2300
DT17UHZ--OKOK
DT20X8ZOKOK--
PUMA Engines.
B71 2302
5W30 oil
B71 2297
5W40 oil
B71 2296
10W40 oil
B71 2300
PUMA (Euro 4 emission control standard)4HV / 4HU / 4HM / MFB--OKOK
PUMA C4HG / 4HH / 4HJ / 4HFOKOK--
SOFIM Engines.
B71 2302
5W30 oil
B71 2297
5W40 oil
B71 2296
10W40 oil
B71 2300
F28DT8140.43S / 8040.23--OKOK
F28DTGV8140.43 N--OKOK
F30DTEF1CE0481D / F1CE3481DM--OKOK
FIAT Engine.
B71 2302
5W30 oil
B71 2297
1.3 HDi 75FHZOKOK
1.0 N3-OK-
YUNNEI Engine.
B71 2297
D20T-OK
Unit D: China
CAUTION: Category ACEA 5W30 C2 , 0W30 C1 / C2 oil must not be used in engines earlier than 2000 (7/99) model year.
TU / ET Engines
Engine typeEngine Identification0/5W30 oil B71 23015W30 oil B71 229710W40 oil B71 2300
TU4 MYFZ-OKOK
TOYOTA Engines
B71 2302
5W30 oil
B71 2297
5W40 oil
B71 2296
10W40 oil
B71 2300
1KR-FECFB-OK-OK
MITSUBISHI Engines
B71 2302
5W30 oil
B71 2297
5W40 oil
B71 2296
10W40 oil
B71 2300
1.6 MMCNKZOKOKOKOK
4K22T-OKOK--
EP Engines
B71 2302
5W30 oil
B71 2297
EP38FSOKOK
EP65FW / 5FPOKOK
EP6CDTX5FU / 5FB-OK
EP6CDTR5FG-OK
EP6FADTXD5GFOKOK
EP6FADTX5GGOKOK
EP6FADTX HP5GBOKOK
EP6LTDTBDOKOK
EP8FADTXD6GZ / 6GYOKOK
EP8FADTX6GXOKOK
EB Engines
B71 2302
5W30 oil
B71 2297
5W40 oil
B71 2296
EB0ZMZOKOKOK
EB2 FFHMZOKOK-
EB2 MHMYOKOKOK
EB2ADTHNF / HNH / HNK / HNPOKOK-
EB2ADT MHNMOKOK-
EB2ADTSHNSOKOK-
EB2ADTS MHNLOKOK-
EB2ADTS-CHNTOKOK-
EB2ADTXHNNOKOK-
EB2DTHNZOKOK-
EB2DT MHNVOKOK-
EB2DTSHNYOKOK-
EB2DTS MHNWOKOK-
EB2A FFHMNOKOK-
EB2FA FKHMFOKOKOK
EB2FA MHMJOKOK-
EB2FA MKHMGOKOKOK
EB2LTDTBDOKOK-
EC Engines
B71 2301
B71 2296
EC5NFPOKOKOK
EC5 (E100)NFNOKOK-
EC8WFZOKOK-
PUMA Engines
B71 2302
5W30 oil
B71 2297
5W40 oil
B71 2296
10W40 oil
B71 2300
PUMA
SOFIM Engines
B71 2302
5W30 oil
B71 2297
5W40 oil
B71 2296
10W40 oil
B71 2300
YUNNEI Engine
B71 2297
D20T-OK
