Hi. Im from Estonia i have read lots of RT6 threads here but not found solution to my problem. Ihave DS5 and i bought the original SW update CD from dealer cost 18.- eur. I started the update. Screen flached 2 time and then aperared... Preapering the update... And nothing more it stayed like this 1hour. It apears the cd just was whirl there. Igot the cd out but now the radio and screen not working. Please can somebody give me link with SW 2.77 that i can but it to USB and try then.
Thankyou.
DS5 2014 RT6 problem-
Moderator: GiveMeABreak
- x 5806
Re: DS5 2014 RT6 problem-
I've sent you a Private Message.
I don't have these as a zip file, but if your CD is damaged, then the link I have provided will allow you to download the image file (ISO), from which you can mount on your PC and extract the files to a USB.
Same thing..it does something..but remains...Prepearing update...and stuck.
- x 5806
Then your internal MicroSD card is probably toast and you should probably have a read of this post:
viewtopic.php?t=63227
Hi. I changed the internal SDcard. And then the SW instalation finished. All working ..radio..bluetooth and rear camera. But sometimes if i put car to reverse gear the camera picture on screen starts and then radio does reset. It happends only in rear gear. Are there something wrong with camera or the 2.77SW does not work properly.?
- x 5806
You may want to try with V2.86 as you have V2.77 installed. My info suggests that DS5 vehicles (CAN2010) with V2.77 already installed will take the V2.86 upgrade without having to reconfigure the system.
If you are going to try this, do take a mirascripts backup now of the user files (as per the replacement guide), but don't restore these back after the 2.86 upgrade unless you need to. You may find 2.86 fixes the issue.
Today i drive like 55km and radio did like 6 times restart ...randomly...sometimes after 10min sometimes 15min...but can yo PM me the latest SW...i put it into usb.
Thankyou wery much. Now radio is ok and working.
- x 5806
