Hi not sure if anyone could point me in the right direction my 2013 2.0hdi van VF7**************[VIN obfuscated, can be read by forum staff] went into limp mode recently only had a cheap code reader with me which suggested a Maf fault Ive since read it with a snap on solus which gave the above codes relating to quantity of air greater than expected and cold air greater than expected. After clearing the fault it stays off until you reach 2k revs when it comes back on. I've read so much about codes which also suggested a possible egr fault. Vans on a 140k and I've not cleaned or replaced it in 40k (egr) could it be gummed shut or would that be a separate code No smoke etc or would I best be looking at split pipework? I did clean the maf and take some readings from it but could only confirm low variable voltage on the signal wires and +12 ground on the others. Im away during the week so just trying to plan where to start once home again
Thanks in advance
P0100 & p129f codes
- x 6917
Re: P0100 & p129f codes
Your VIN is incorrect. Please check again and re-post it - focus on the last 8.
Thankyou Marc ..8dz048208
- x 6917
Hopefully these will give you some pointers:
Fault Code: | P0100 |
Description of Fault: | Air flow meter : Quantity of air above the maximum threshold. With engine speed at 2000 rpm and turbo air pressure at 2 bars, the fault appears if the air flow measured is greater than 1300 mg/stroke for 2s. With engine speed at 3000 rpm and turbo air pressure at 2,5 bars, the fault appears if the air flow measured is greater than 1500 mg/stroke for 2s. Conditions of activation of the diagnostics: The following conditions have to be met: - Engine speed above 1500 rpm - Battery voltage between 10 and 16 V |
Conditions for Fault to clear: | Driving for 5 minutes with several full load accelerations for 10 seconds (Engine hot): With foot off in between. |
Downgrade Modes whilst Fault is active: |
Symptoms: |
Suspect Areas: |
Fault Code: | P129F |
Description of Fault: | Air circuit: Quantity of fresh air above the reference value (APV). The measured air flow is greater than the reference by more than 80 mg/stroke for 8 seconds. Conditions of activation of the diagnostics:
Conditions for Fault to clear: | Vehicle driven for 5 minutes, remaining below an engine speed of 2500 rpm. |
Downgrade Modes whilst Fault is active: | - |
Symptoms: |
Suspect Areas: |
It does much appreciated Marc thankyou
