Hi guys,
does anyone have the wiring diagram of the RNEG? ...I want to know what the pins of the folding screen are for...
Complete Wiring diagram RNEG
Moderator: GiveMeABreak
- x 5852
Re: Complete Wiring diagram RNEG
Pins 9 & 11, 14 & 15:
Part "A": 16 way connector
Channel number | Allocation of channels of connector |
1 | signal : Right hand rear speaker |
2 | signal : Front right hand speaker |
3 | signal : Front left hand speaker |
4 | signal : Rear left loudspeaker |
5 | Earth : Right hand rear speaker |
6 | Earth : Front right hand speaker |
7 | Earth : Front left hand speaker |
8 | Earth : Rear left loudspeaker |
9 | Supply : Retractable multifunction screen DEV |
10 | Comfort CAN High |
11 | Retractable multifunction screen position return signal DEV |
12 | Battery + supply |
13 | Comfort CAN Low |
14 | Opening : Retractable multifunction screen DEV |
15 | Earth : Retractable multifunction screen DEV |
16 | Earth |
Hi, i mean the flipscreen connector (d) .
I thinking this one is the Part A, B en C ...not the D connector
- x 5852
That is for the LVDS connection to the Multi Function Screen:
Application: 10-way black connector
Terminal | Allocation of channels of connector |
1 | Clock LVDS CLK1 + |
2 | Clock LVDS CLK1 - |
3 | - |
4 | Channel LVDS A0 + |
5 | Channel LVDS A0 - |
6 | Channel LVDS A2 + |
7 | Channel LVDS A2 - |
8 | - |
9 | Channel LVDS A1 + |
10 | Channel LVDS A1 - |
Thanks for your attachment, but I see now that it's not really clear to me what the names mean. I was hoping to find out the video channel.
- x 5852
The LVDS is the video input to the screen. The channels are for the different video and info data streams IIRC.
Can you post the complete wiring for parts B and C?
Im installing a bluetooth module directly into the radio instead of the aux connector which I never used. I swapped pins for left, right and earth audio, pins 4, 10 and 11 in parr B but I dont know if there is a pin for power supply. It'd be very usefull.
Thank you so much.
Thank you so much.
- x 5852
Part "B": 12 way connector
Part "C": 12-way black connector (Only with CD changer)
1 | Earth : CD player |
2 | VAN Low : CD player |
3 | Permanent + : CD player |
4 | Left audio system : CD player |
5 | - |
6 | - |
7 | CAN High : CD player |
8 | Earth : CD player |
9 | - |
10 | Left audio system : CD player |
11 | - |
12 | - |
5 | - |
6 | - |
9 | - |
11 | - |
12 | - |
Thank you so much GiveMeABreak
A friend of mine contacted me to ask if I could do the same in his peugeot3008, he has the WIPNAV navigator.
Would you be so kind to post the wiring of this navigator?
I need the same as the other one, a power supply connection, ground, and aux.
Thank you so much!!!
- x 5852
This is the WIPNAV system I have provided above.
Are you sure he doesn't have another system like WIPNAV+ or WIPCOM 3D?
If he's not sure, best to pop his VIN up.
Ok, it's the same as mine, i though they were different. He has no usb in the aux, and the main unit has a sd card slot, so it's a normal wipnav. If I'm not wrong... xD
One question, the channel numers with "-", is there any way to know what they can be used for? Or are they just blank connectors with no use at all?
- x 5852
They are not used and therefore are useless as they don't connect to anything.
