Citroen fleet update AX, ID and CX
jsp
x 12
Unread post by jsp »
hi, just started a project. 1994 Citroen AX 1.4 TGS E2 with electric windows and sunroof about 200k km.
Some of the Citroens I have at the moment:
1960 ID:
1987 CX GTI Turbo 2:
1984 CX GTI Turbo 2 and Citroen AX 1.1 spot 1996
And Another AX 1.1 spot 1996:
Picked her up 160mls from my house:
Oops towcar in front flipped had to stay 50min in the congestion:
Bought a MPH dash through a good acquaintance:
jsp
x 12
Re: Citroen fleet update AX, ID and CX
It's been moted (it failed)
Headlight not attached correctly.
sills both sides L + R.
After MOT a few days later we started fixing the sills by welding new pieces into it:
jsp
x 12
After welding the sills it passed the MOT:
Oops:
During welding the sills so had to redo the whole fuel system.
jsp
x 12
Sorted the white smoke issue:
x 94
Unread post by citronut »
jsp wrote:
Oops:
very lucky she didnt go up in flames there then,
would definitely been a hot hatch
Regards, malcolm.
jsp
x 12
citronut wrote:
jsp wrote:
Oops:
Used a fire extinguisher to be safe.
jsp
x 12
Upgraded my Dark green AX alternator to 70A and starter to a valeo one. Starts much better and less weight.
jsp
x 12
Dark green AX.
Well it seems the old alternator almost ran till his end of life:
Old one measure only 12.9V
New one 14.5V
jsp
x 12
My wiper motor went slower and slower and gave up yesterday. I couldn't drive the car until it has been fixed as it has been raining the whole week:
And also found some AX GT wheels for spares:
jsp
x 12
Got my GTI block last Saturday:
No sludge in this engine:
Some almost new spark plugs:
Got a AX GTI brake booster:
jsp
x 12
Some progress on the GTI Engine (degreased and hammerited it):
Degreasing the rest aswell:
Degreased baffle plate:
Washerbottle neck changed to a Saxo one:
jsp
x 12
Parts degreased:
Tow hook rust removed using sandblasting and recoated against rust:
jsp
x 12
While exchanging the engine I replaced the voltage regulator aswell on the alternator:
jsp
x 12
Engine is swapped:
Temprature correct without thermostat:
New wiper to replace the temporary wiper:
Need to fix this gauge aswell:
jsp
x 12
Fixed another ignition module for the CEL. It's staying off now:
Radio is zooming without this:
GTI interior bits:
Changed the clock lamp to yellow:
