Laguna engine
This is the Forum for all your Renault Technical Questions, Problems or Advice.
Stu_m
Laguna engine
Unread post by Stu_m »
Hi all im new here and im after picking your brains :)
the father in laws 2000 model laguna has just killed its cam belt and buggered the engine
does anyone know what other engines will fit in it if any ?
the car is a 2000 1.6 16valve laguna with engine code K4M F7/20
i have seen a few engines with the same code one of them is an 05 megane/scenic with 19k on the clock engine code K4M A700
does anyone know if this will fit and if the gearbox will mate to it also would the origanal ECU from the Laguna work ok with it ?
any help greatly appreciated
Thanks Stu
Stu_m
anyone :?
