Got a V Reg Megane RT Sport, on my way home from work the car made a little judder from engine then died, it wouldnt restart with key so i bumped it while it was still moving, it started up for a few seconds then cut-out. towed rest of way home and started looking around forums for possible causes and fixes, tried tdc and lambda sensors, fuel pump is ok. still wouldnt start, father in law a mechanic but he was going on holiday day after (just my luck) and didnt want to start messing with it, suggested i take plugs out and see if they sparking, which i did and they are. a friend of mine came and had a look and he take oil filler cap off and asked me to turn engine over, which resulted in no movement at the top of the engine which he said was the timing belt which has gone
thanks again for your help in advance, hope i get it sorted as i really like the car.
ps: sorry if i went a bit too indepth with description, just wanted to give as much as i could
