Reprogramming of the central locking is easy...
The reprogramming is a simple procedure.
1. Turn on the ignition
2. Within 10 seconds hold the original plip pointed at the sensor, about 8" away from it and press either button
3. Within a further 10 seconds do the same for the new plip. (you see you need a spare key - or remove the blade)
4. Turn off the ignition and test plip.
this procedure covers 94 to 99
306 plip reprogramming
